August 12, 2025, 12:15:41 PM *
Author Topic: water in sarkplug hole  (Read 1195 times)
Greg aka smoothrider ?
A,O,S, LET'S ROLL
CLINTON TENNESSEE
« on: November 04, 2012, 03:13:24 PM »
 I get water when I wash my bike in around the sparkplug and it shorts the plug out is there a drain and if there is where is it? I looked for a drain used compresser to blow it out but it still gets in. I have to take the pod off pull the plug cap off and take a paper towel and get the water out every time I wash my bike !
''LIVE LONG AND PROSPER''
Thunderbolt
Worthington Springs FL.
« Reply #1 on: November 04, 2012, 03:22:18 PM »
Yep, there is a drain in each sparkplug hole.  You should be able to take a piece of wire like 20 gauge or so and run it through each drain hole.
« Reply #2 on: November 04, 2012, 03:34:51 PM »
You might be able to see it better from underneath. That will give you a better idea of where it's located, but T'bolt is correct....they do have a drain hole.
« Reply #3 on: November 04, 2012, 05:25:26 PM »
The OEM sparkplug wires cover the recession the plugs are in.  Do you have aftermarket wires?  Hoser   ???
« Reply #4 on: November 04, 2012, 05:27:57 PM »
Stop hitting them with a hose.
Use a leaf blower to remove water before wipe-down.
Chrome
London Ontario Canada
« Reply #5 on: November 04, 2012, 05:43:23 PM »
Hey Hoser
Yes they cover but not water tight.This is what happens when the weep hole clogs and the plug rusts.Cleaned up OK but still a pain.
Adrian
2001 Valkyrie I/S
1999 Valkyrie I/S
1998 Ace Tourer
1984 V45 Sabre
1976 CB 750 SuperSport
1969 CB 750 Chopper
A,O,S, LET'S ROLL
CLINTON TENNESSEE
« Reply #6 on: November 04, 2012, 11:09:03 PM »
Thanks for all the info that picture looks like my bike! I'll try to find it, we looked but didn't see one. I'll look under it tomorrow! is the hole in front or in back of the plug? thanks Men!
redflash
Southern New Hampshire
« Reply #7 on: November 05, 2012, 04:17:54 AM »
Weed whacker string (plastic) works great for unclogging them! A little "Deep Creep" helps too.
9Ball
« Reply #8 on: November 05, 2012, 04:27:45 AM »
also, good advice was given regarding NOT spraying down with water... cooldude
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
Bone
« Reply #9 on: November 05, 2012, 04:49:34 AM »
Pull another plug boot to see the hole location.
If the valve cover is at 6:00 the hole is at 5:00.
« Reply #10 on: November 05, 2012, 05:06:37 AM »
Hey Hoser
AdrianH
Thanks for sharing those pics, they are "gross".  Kiss  I don't usually turn a hose on my bike, but when I do I'll pay particular attention to blowing out the spark plug holes
My rides:
« Reply #11 on: November 06, 2012, 05:54:47 AM »
Hey Hoser
Adrian
My oem wires don't leak, there is a little ridge around the plug hole, the covers snap over them, just jam them on with gusto.  keeping the drain hole clear is important, but I have never seen my plugs look anything like your pics.  I hose wash it all the time, but no power washer used.  coolsmiley Hoser
