August 12, 2025, 12:17:44 PM *
Author Topic: Interstate Trunk Liner  (Read 1100 times)
bikerboy1951
Grand Forks, ND
« on: November 08, 2012, 03:34:14 AM »
I know this is going to sound stupid, but how do you get the trunk liner out to run speaker wires.  I removed the screws around the top lip, the five screws that hold the shield in the front and the three screws that go into the latch in back.  I can't get it to come out.  What am I missing.  I looked on the picture breakdown of the trunk, but it doesn't help much.
Brad
cef2lion
Central PA
« Reply #1 on: November 08, 2012, 06:50:43 AM »
I had mine out while the trunk was off the bike. Been two years. Is there a chance you need to remove the bolts that hold the trunk to the bike as well?
Michvalk
Remus, Mi
« Reply #2 on: November 08, 2012, 06:52:54 AM »
I had mine apart many years ago and can't remember. Trunk is off the bike? Are you sure you have all the screws? Taillights out? Mine came out real easy once I had all the screws. Maybe someone will have some recent experience cooldude
MartinT
San Mateo CA
« Reply #3 on: November 08, 2012, 06:56:35 AM »
you need to remove the rubber strip that sits along the top ridge of the bottom part. Its glued on, but you can remove it by careful pulling and prying without tearing it up. There are about 27 little screws underneath that hold the liner to the bottom trunk. Remove those and you're done. Just re-glue the rubber strip with some rubber cement, so you can repeat the process in the future if needed.
Martin
tank_post142
south florida
« Reply #4 on: November 08, 2012, 12:47:54 PM »
there are 5-6 small screws coming up from the bottom side of the trunk. the bolts that mount the trunk need to be removed also.
« Last Edit: November 08, 2012, 12:49:32 PM by tank_post142 » Logged
I got a rock Sad
VRCCDS0246
bikerboy1951
Grand Forks, ND
« Reply #5 on: November 08, 2012, 02:11:27 PM »
Where is the plug on the bike for the rear speaker wires?
Brad
bikerboy1951
Grand Forks, ND
« Reply #6 on: November 08, 2012, 02:51:31 PM »
Finally got it apart.  Had to remove the rubber grommets as they help hold the two halves of the runk together.
Now, where is the plug that the rear speakers plug into.
Brad
Michvalk
Remus, Mi
« Reply #7 on: November 08, 2012, 05:55:41 PM »
Under the right sidecover cooldude
NITRO
Eau Claire, WI
« Reply #8 on: November 08, 2012, 06:31:11 PM »
Electrical connections makes a wiring harness that snaps right into the plug under the right side cover. Or you can just tie into those wires with some solder.
When in doubt, ride.
bikerboy1951
Grand Forks, ND
« Reply #9 on: November 08, 2012, 08:54:50 PM »
I bought the electrical connection harness, but I can't find the place it plugs into.  One place I read said that it was in one of the plastic sleeves.  I looked in them and no connector.  I found the connectors for the cb and cb antenna coming off the radio.
Is it a plug coming off the radio.  Not really sure where to look for it under the right side cover.
I just got this bike yesterday so am trying to learn asap.  I have a stnadard, but not the same beast.
Brad
