November 25, 2025, 02:51:26 PM
Progressive shocks and springs installed
Topic: Progressive shocks and springs installed (Read 1208 times)
Freep
Bayfield, CO
November 08, 2012, 05:18:54 PM »
Had a leaky fork seal so took this opportunity to change out the front springs and rear shocks for progressive fork springs and 412 shocks.
Only about 35 miles on 'em so far but much better ride.
I found that if you pull both rear shocks then put a 2x4 on a floor jack under the luggage rack you can stretch things enough to get everything bolted up. I had the dealer do the forks.
Out of morbid curiosity, what's the going rate for changing out fork seals?
Last Edit: November 08, 2012, 05:26:36 PM by Freep
Freep
Keep thine eye upon thine tach and thine ears upon thine engine lest thy whirlybits seek communion with the sun. John 4:50
keepinon
New Caney, Tx
Re: Progressive shocks and springs installed
November 08, 2012, 08:35:59 PM »
I carried just the forks to the stealer here, $205 for seals & bushings, their parts.
1998 GL1500 CT Trike
November 09, 2012, 04:38:02 AM »
$300. I carried in the forks, with loosened caps, and supplied the fluid. They didn't change
the seals or anything else. Five years ago. That's the only part of my bike (since I've owned it)
that has ever seen a dealer...
olddog1946
Moses Lake, Wa
November 09, 2012, 10:06:42 AM »
I bought new bushings, sliders seals and progressive springs and took the forks into the dealer, while I waited and was charged 86 bucks for the labor and fork oil.
But all labor depends on what the stealer charges in your neck of the woods, which can be drasticly different in different areas.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
Moses Lake, Wa. 509-760-6382 if you need help
PharmBoy
Lawton, Ok
November 09, 2012, 11:36:17 AM »
Chancing the seals is a pretty quick job if you have the right tools and know what to do next. There is usually a lot of head scratching time added on if the mechanic isn't farmiliar with the valkyrie forks. I've done 5 pair since last spring and it just gets quicker with each change...Jim
4th Infantry Tet Vet
99 Interstate
97 Bumble Bee
97 Red & White
=> InZane XXV
