February 06, 2026, 02:25:18 AM *
Author Topic: Side cover  (Read 1479 times)
Moonshot_1
« on: November 10, 2012, 03:00:34 PM »
Cleaning up the bike this afternoon. Pull off the right side cover. All appears fine and dandy.
Go to put it back on and I can't get it to "lock" in so to speak. It has 3 points that it affixes to the bike.
The lower tab, the side with the grommet , and the upper tab on the front that has a small rectangular hole. It is where this upper tab towards the front fits into that is the problem. It fits into a slot in the center panel where THERE USED TO BE A TAB that fit into that rectangular hole. It broke off flush with in the center panel hole. Tiny little plastic tab. Any solutions?
Right now I got it jury rigged with a paper clip. Stuck it through the hole in the cover tab and bent it so it so when I insert it into the center panel it applies a degree of pressure and holds the corner of the side cover in place. It's not a bad fix but looking for something more conventional and looks good.
Glue is not really an option.
Then I went and tore a grommet on the other side panel. It's holding but will need a new one.
Mike Luken
Cherokee, Ia.
Bone
« Reply #1 on: November 10, 2012, 03:28:08 PM »
It's easy to break that tab. The guys have a fix with pictures try a search.
They rebuild the tab.
Here is one link; http://www.vermin-club.org/mods/side_cover_tab_repair.htm
« Last Edit: November 10, 2012, 03:52:22 PM by Bone » Logged
« Reply #2 on: November 10, 2012, 03:46:40 PM »
Same ptoblem on my I/S. Fixed/repaired mine with sticky back Velcro Tape. RIDE SAFE.
Moonshot_1
« Reply #3 on: November 10, 2012, 03:56:04 PM »
oo I like that one. Will give it a shot.
Mike Luken
Cherokee, Ia.
mmurffy03
03 standard
toms river new jersey
« Reply #4 on: November 10, 2012, 04:34:02 PM »
small piece of clear scotch tape
« Reply #5 on: November 10, 2012, 08:43:01 PM »
A more permanent fix would be to just replace the center and side cover.  There's usually some on ebay.
Imohtep
Helsinki, Finland
« Reply #6 on: November 10, 2012, 09:00:40 PM »
And break it again..Smiley
http://vrcc.photostash.com/vrcc_32485/MIMG_1492.jpg
Valk with supercharger...that's it!
#32485
« Reply #7 on: November 10, 2012, 09:21:21 PM »
Gotta be careful.   Wink
I've broken my share already.   cooldude
« Reply #8 on: November 10, 2012, 10:06:45 PM »
Mike, both of my side panels have a missing ear.
Now, they wear velcro on the frame post.
Been holding like that for about 150K.
I think if memory serves me correctly, I had to change
the velcro on one side.
You can order a new grommet from HDL, or have the
Honda dealer in Storm Lake get ya one.
