February 06, 2026, 02:25:24 AM
Seat lock issue
Topic: Seat lock issue (Read 1165 times)
Toledo Mark
Formerly Zeus661
Rossford, Ohio
Seat lock issue
November 11, 2012, 04:49:00 PM »
Have a problem with the seat lock. Key will not turn it to unlock. I got the seat off but want to know the best way to unfeeze the cable.
What should I take apart first? What is the best way to repair it?
Dropbox
is a neat app I found that I use to store files and pictures of my Valk.
Re: Seat lock issue
November 11, 2012, 06:32:16 PM »
Does the key turn freely if the seat is already off?
If so, it is like my seat. I have to push down on the nose as I turn the key.
Been that way since 1997.
Too lazy to fix it.
PhredValk
Edmonton, Alberta, Canada
Re: Seat lock issue
November 11, 2012, 10:11:02 PM »
I agree with RJ. When I use the sheepskin, I tuck it under the nose of the seat and have to push the nose down to unlock the seat. If that works for you, great.
If you need to replace the cable, I suppose you can get one from HDL Parts; but having removed the lock from the center cover when I installed the engine hanger covers I can tell you that it's a b*tch to get at unless you have very small hands.
Fred.
VRCCDS0237
Grandpot
Fort Mill, South Carolina
Re: Seat lock issue
November 12, 2012, 08:06:38 AM »
I just oiled my cable and put a dab of grease where the latch contacts the seat. Been working fine since then.
Experience is recognizing the same mistake every time you make it.
