February 06, 2026, 02:19:32 AM *
Author Topic: CDI Box  (Read 1420 times)
Mallett
Oh, what a ride!!!!
Laurel, Mississippi
« on: November 11, 2012, 05:26:55 PM »
How do you change The CDI box? I have a Dyna 3000 but ordered a OEM for backup...
Any coward can fight a battle when he's sure of winning; but give me the man who has pluck to fight when he's sure of losing.
GEORGE ELIOT
Challenger
« Reply #1 on: November 11, 2012, 06:38:01 PM »
Remove side cover, unplug Dyna, Remove Dyna from rubber boot, plug in new CDI box, Install in boot, replace side cover
Mallett
Oh, what a ride!!!!
Laurel, Mississippi
« Reply #2 on: November 11, 2012, 06:43:41 PM »
Looks to me like it needs to unplug from the top but frame is in the way....
GEORGE ELIOT
valky1500
MI
« Reply #3 on: November 11, 2012, 07:53:51 PM »
Actually it unplugs from the bottom, underneath the unit, and there isn't much play down there at all. What I mean is that you will need to loosen if not remove the water bottle, very carefully so you don't break off the nipple in which can happen very easily. That's just to get your hands in there enough to grab a hold of the plug to remove the ECU.
I suggest swathing the insides of the plug holder (bottom part of the ECU) with a dialectic grease just to keep things fresh for later use when reassembling.   coolsmiley
'98 Standard
'01 IS
Yes I pull a trailer
I have taken notice to those who use that word (Precautionary) and abide by it are not only very happy in life...
but they also live long and prosper.  Wink
Jabba
VRCCDS0197
Greenwood Indiana
« Reply #4 on: November 12, 2012, 03:46:21 AM »
as I recall, I pulled mine out... then unplugged it.
My memory sucks though...
I do remember it was not hard at all.
Jabba
Joevalk
Santa Fe, Texas
« Reply #5 on: November 12, 2012, 04:45:32 AM »
Just send me the 3000 and ill send you mine off my standard.
You don't have to send no money, even trade. HEHE
VRCC#32720
1999 Grn/Silver Interstate
Mallett
Oh, what a ride!!!!
Laurel, Mississippi
« Reply #6 on: November 12, 2012, 04:49:38 AM »
Haha Joevalk...the 3000 is great...just wanted a insurance policy in the saddlebag...Smiley
GEORGE ELIOT
Joevalk
Santa Fe, Texas
« Reply #7 on: November 12, 2012, 04:53:41 AM »
I unbolted the over flo tank and pulled the module out.  10mm bolts holds the tank on, I believe.
VRCC#32720
MP
North Dakota
« Reply #8 on: November 12, 2012, 06:06:45 AM »
+1.  Need to remove the tank.
MP
"Ridin' with Cycho"
Farther
Quimper Peninsula, WA
« Reply #9 on: November 12, 2012, 06:37:57 AM »
I went through several ICM removal/installs when I first got my Dyna and it help the first time to remove the coolant overflow container.  After the first time I was able to do the swap with the container in place.  It's probably wise to carry a back-up for the Dyna.
~Farther
valky1500
MI
« Reply #10 on: November 12, 2012, 10:05:13 AM »
What I liked and miss most about the Dyna 3k was being able to set the rev limiter higher than the stock setting.  Grin
'98 Standard
'01 IS
Mallett
Oh, what a ride!!!!
Laurel, Mississippi
« Reply #11 on: November 12, 2012, 02:36:22 PM »
Well I wimped out...took the side cover off & bolt out of the tank & leaned it forward...still could not see how there would be enough room to pull the Dyna out of the boot...guess I'll just put the CDI I bought in my saddlebags & hope that it's a good one...sure wanted to test it tho....
GEORGE ELIOT
