February 06, 2026, 02:24:59 AM *
Author Topic: turn signals  (Read 1557 times)
henry 008
BRP
willard, oh
« on: November 13, 2012, 12:12:11 PM »
where would i find the link to rebuild the turn signal switch with dielectric grease? i need to do something. last couple yrs, whenever its below 50*, the turn signals are VERY slow to react.  or maybe i need to add some blinker fluid  uglystupid2
Safe Winds... Brother
ryord
« Reply #1 on: November 13, 2012, 12:47:54 PM »
I had the same thing happen to an old car I used to own, when the temp dropped the blinkers would go slow, I replaced the blinker relay, That solved the problem for me. I would check that.
« Reply #2 on: November 13, 2012, 12:49:39 PM »
I did mine 2 yrs ago. Its pretty forward once your in there. Just watch the little parts. Worked good for a yr but they are getting slow again. I need to do it again.
« Reply #3 on: November 13, 2012, 02:31:33 PM »
Don't know of a link, but it just comes apart with a couple screws.
No flying jack-in-the-box springs....just pry it apart.  Spray out the old gunk with some contact cleaner and re-lube with fresh dielectric grease and reassemble.
The switch action will be smother too.   cooldude
http://www.valkyrieriders.com/shoptalk/GL1/gl27.jpg
henry 008
BRP
willard, oh
« Reply #4 on: November 14, 2012, 12:06:42 PM »
thanks guys!  cooldude
they are not blinking slower,  its that i hit the signal and its 10sec or more before they start blinking.   Wink
hal47
INDIANA
« Reply #5 on: November 14, 2012, 03:43:20 PM »
Hi Henry mine did the same thing,if I remember right you undo a screw or two them the side of the switch pop off with a little presure.Clean it out and apply new grease and slightly stretch the spring.  Hope this helped.
