February 06, 2026, 02:25:20 AM *
Author Topic: Help needed - putting Standard fender on I/S with CB  (Read 1173 times)
Super Santa
VRCC #27029
Houston, Texas
« on: November 13, 2012, 06:32:02 PM »
Need assistance figuring out how to do it.
Have lights wired and functional.  Problem being the tail light on Standard fender hits the CB unit mounting under the trunk.
Suggestions would be greatly appreciated.
Also, still looking around for an Interstate lower trunk box in BLACK.  Already have a couple located that are two tone.
« Last Edit: November 13, 2012, 06:45:52 PM by Early Bird » Logged
F6BANGER
Albuquerque NM
« Reply #1 on: November 13, 2012, 06:43:03 PM »
Hey Ray,
You either have to find another location for the CB or take the light off. I have a light for a VTX that I am gonna try to make fit sometime this winter.
« Reply #2 on: November 13, 2012, 07:18:47 PM »
I have read that the CB will fit under the trunk with the tail light in place, if you change the mount... seem to remember turning it sideways.
Tri Dragon
2001 Valkyrie Interstate Trike
Campbell River, BC, Canada
« Reply #3 on: November 13, 2012, 07:38:00 PM »
Ray, I put My CB under seat next to battery. There is slot for manual that I used dremmel tool to remove dividers. Cb fit good and I routed wiring easily to connections. Keeps it out of weather also.
Terry, ps I have 2001 IS
Ride what you want and Ride it until you Rot!
PharmBoy
Lawton, Ok
« Reply #4 on: November 14, 2012, 12:28:18 PM »
Under the seat next to the battery sounds like the best place for the CB if you want to keep the tail light.  I would have put it there, except I have part of a Kennedy sound system and part of an electronic cruise control in there.  I hung the CB bracket on the wall and attached the CB to the top part of the left trunk support with a couple of medium duty tiewraps.  The front inboard corner of the CB rests on the front part of the tail light lens with a thin piece of rubber between them.  The CB huggs the bottom of the trunk with the attachments facing forward.  Sounds like a jury-rigged deal, which it is, but it has not moved in 18 months, is out of sight, and works for me...Jim  Smiley
4th Infantry Tet Vet
99 Interstate
97 Bumble Bee
97 Red & White
