February 06, 2026, 02:25:33 AM
Start switch install
Topic: Start switch install (Read 1215 times)
deav55
Iowa
November 13, 2012, 07:31:31 PM »
I have a 97 standard and the start switch not dependable so I purchased an OEM replacement. Any ideas on removing the throttle cable to install the new start, kill switch assembly?
Re: Start switch install
November 13, 2012, 07:35:07 PM »
If you're having the problem I think you're describing, you can loosen the risers and
slide your handlebars to the left and there will be plenty of slack in the throttle cables...
The handlebars will try really hard to swoop down and put a big dent in your tank as
soon as you loosen the last riser bolt, so put some thick layers of towels over your
tank or something to prevent that from happening...
deav55
Iowa
November 14, 2012, 02:22:50 PM »
Will ck it out Thanks...
