February 06, 2026, 02:25:32 AM *
Author Topic: OK, I give up !!  (Read 1665 times)
olddog1946
Moses Lake, Wa
« on: November 15, 2012, 09:00:14 AM »
My next door neighbor has a 97 Valk Std. and one of the lights in the speedo is out. According to the CD I have the odometer reset knob has a screw holding it in.  Well, I see NO screw, not can I get it off. Must be my old eyes. Can anyone tell me how to get that knob off. Don't want to break someone elses bike. I do good enough on my own. crazy2
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
JC
The Beast
Franklin, TN
« Reply #1 on: November 15, 2012, 09:02:53 AM »
There's one in there for sure. It takes a #1 or 0 phillips, then the knob should just pull off.
paps350
Pittsburgh Pa
« Reply #2 on: November 15, 2012, 09:30:08 AM »
There is a black rubber plug in the end which gives access to a small phillips head screw.
olddog1946
Moses Lake, Wa
« Reply #3 on: November 15, 2012, 09:39:14 AM »
Thanks fellas, I'll be changing out my steering stem bearings today and will see if I can get his light done as well.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
donaldcc
Palm Desert, CA
« Reply #4 on: November 15, 2012, 10:21:42 AM »
  OK I went out to look at mine and I can see the phillips head screw (#24) down in the knob (#10).  But I do not have a black rubber plug in the knob and don't see that piece in the parts diagram below.
http://www.hdlparts.com/fiche_section_detail.asp?section=2552209&category=Motorcycles&make=Honda&year=1997&fveh=132667
Don
9Ball
« Reply #5 on: November 15, 2012, 11:55:36 AM »
because it's not typically there....you're ok.  My 1999 and my buddies 2000 don't have a rubber plug either.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
olddog1946
Moses Lake, Wa
« Reply #6 on: November 15, 2012, 09:13:16 PM »
If mine or Chiko's has a rubber plug I can't see it. Probably due to my crappy upclose vision. I can't see the head of the screw either.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
WamegoRob
Wamego, KS
« Reply #7 on: November 15, 2012, 09:54:09 PM »
Mine has no rubber plug either but the screw is in there.  Just get a super-tiny cross-tip screwdriver and get at it.
9Ball
« Reply #8 on: November 16, 2012, 03:06:25 AM »
Yes, it's a tiny screw....2 mm.  It's easy to round off the head if you use too big of a Phillips screwdriver.
1999 Standard
2007 Rocket 3
2005 VTX 1300S
