February 06, 2026, 02:25:27 AM *
Author Topic: Motosen gauges on Interstae  (Read 1849 times)
mikochan
Syracuse, NY
« on: November 17, 2012, 06:39:25 AM »
Wondering if anyone has installed a couple Motosen gauges on an Interstate? I would like to mount a water temp and volt meter on my bike but haven't found a good spot. Probably get the flat gauges for easier mounting.
« Reply #1 on: November 17, 2012, 09:25:16 AM »
If you do that, I'm sure we'll be seeing a lot more posting caused by all the worry those gauges will cause you.
I'm serious, just search the archives and you'll understand where I'm coming from.
« Reply #2 on: November 17, 2012, 11:10:14 AM »
Last year I pulled into a gas station and turned off the Valk.  The volt meter indicated under 11V.  I got gas, rode to Wally World, removed the battery and sure enough bad egg!....Got a new one charged it and never had a worry about it in the world.
Dont know why having a Voltage indicating device should worry anyone (or a water temp indicater for that matter) These guages are quite standard on cars now so we should be used to interpreting the readings.
PhredValk
Edmonton, Alberta, Canada
« Reply #3 on: November 17, 2012, 12:17:00 PM »
Some people have a Voltmeter mounted on the rear panel of the left radiator pod. I think that's where I'll mount mine. It's a very bright LED out of the surplus aisle at Princess Auto, and I think it would be distracting on the dash, especially at night.
Fred.
VRCCDS0237
ptgb
Youngstown, OH
« Reply #4 on: November 17, 2012, 09:10:17 PM »
Here's what I did with mine:
I have since lined them up better, but they work great.
I pulled the cable cover and drilled two properly spaced holes for the front most gauges. The other one is the factory hole. I added longer bolts with chrome spacers to get the gauges out a bit as to see them easier over the tank. Easy to see at a glance.
MP
North Dakota
« Reply #5 on: November 18, 2012, 06:05:53 AM »
I have a Motosen voltmeter, and mounted it in the RH pod.  Works great.
MP
"Ridin' with Cycho"
MP
North Dakota
« Reply #6 on: November 18, 2012, 06:07:49 AM »
With that reasoning, I would have had a stroke, a heart attack, and look even older than I do.  My Peterbilt has 23 gauges on the dash! About the only gauge I do not have, is one that shows my personal body temperature!
MP
"Ridin' with Cycho"
sugerbear
wentzville mo
« Reply #7 on: November 19, 2012, 06:47:28 AM »
............just............... ???
Valkpilot
What does the data say?
Corinth, Texas
« Reply #8 on: November 19, 2012, 06:11:08 PM »
MP
Uhmmm...where would "install" the sensor for that?
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
