February 06, 2026, 02:25:19 AM *
Author Topic: fuel stabilizers  (Read 3454 times)
Roadog
« on: November 18, 2012, 06:11:43 AM »
  Used to use Sta-Bil until I saw it separate on the shelf, use Sea Foam now but it has gotten $$$, dont know anything about B-2 Chem Tool.  Have been told that Sea Foam is hard on carb parts, rubber and plastic parts.  I have used Sea Foam a good while with no issues...so far.  What do you use and why ? Thanks.
TLB
« Reply #1 on: November 18, 2012, 06:41:42 AM »
Use Seafoam! Chemtool is hard on rubber parts, but works better in cleaning up carbs IMO.
My rides:
« Reply #2 on: November 18, 2012, 06:42:10 AM »
Im not sure the B-2 is a fuel stabilizer. I dont remember. I usually use sea foam but I found STP makes the same thing but alot cheaper so I'm giving it a try.
« Reply #3 on: November 18, 2012, 06:47:28 AM »
Check this thread out too!   coolsmiley
http://www.valkyrieforum.com/bbs/index.php/topic,49371.0.html
My rides:
« Reply #4 on: November 18, 2012, 09:04:30 AM »
I'm a Sea-foam guy,, been using it for 40 years.. It doesn't hurt anything like the others can do..  I buy this stuff by the gallon.. I've tried Sta-bil,, and its junk as far as I'm concerned..
dreamchaser
Portland, Oregon
« Reply #5 on: November 18, 2012, 09:52:50 AM »
Try Startron, you will like it.  Low price, very concentrated and does what it claims.  It has pleased me more than once.   Gary
Farther
Quimper Peninsula, WA
« Reply #6 on: November 18, 2012, 12:25:35 PM »
I use Sta-Bil Marine Formula with good success.  My brother, who live in Minnesota, used the Sta-Bil too and his bike starts every Spring.
~Farther
Motorider
Pennsylvania
« Reply #7 on: November 18, 2012, 04:34:43 PM »
Good reading on this subject, http://www.biobor.com/Practical-Sailor-Fuel-Additives-That-Fight-Corrosion.php
« Reply #8 on: November 18, 2012, 07:16:36 PM »
Motorider thanks for sharing the great article. It makes good old Seafoam look pretty good.
My rides:
« Reply #9 on: November 19, 2012, 10:04:29 AM »
Yes,, I agree.. Thats a good article.. I've never liked additives,, but,,  A friend that owns the local marina [ mercury] recommended Sea-foam about 40 years ago rather than sell me carburetor kits.. I like it because it works and doesn't hurt anything.. I found the comparison interesting..
NITRO
Eau Claire, WI
« Reply #10 on: November 19, 2012, 10:55:51 AM »
The tech writer from Cycle World recently recommended startron over all the others. I've used sta-bil in the past, will be switching now.
When in doubt, ride.
Farther
« Reply #11 on: November 19, 2012, 11:26:17 AM »
I used both Sta-Bil and SeaFoam in the past but will be switching to only SeaFoam based on that article.  Too bad SeaFoam dosn't come in the convienent dispenser bottle like Sta-Bill does.
~Farther
Aquaman
Clinton Township,MI
« Reply #12 on: November 19, 2012, 02:20:31 PM »
What about Amsoil fuel stabilizer ? They have been around a long time & I personally think they have one of the best synth oils out there !
t-man403
Valk-a-maniac
Calgary, Alberta, Canada.
« Reply #13 on: November 20, 2012, 09:25:47 PM »
I use Ams-oil in my bike but Seafoam for cleaning periodically and as a stabilizer. Great product!
Never thought of looking to Ams-oil for a stabilizer. Might have to check into that for the heck of it.
T.P.
Apple Valley, Minnesota.
« Reply #14 on: November 21, 2012, 09:06:46 AM »
From my October post.
 Re: Mixing additives
« Reply #11 on: October 22, 2012, 08:33:55 PM » Quote Modify Remove
I stopped by Sea Foam A few years back to talk with Technical Service Manager Jim Davis about Sea Foam use for long term winter storage. he said it would not be a problem to use a whole can per tank. since 2004 I have used a whole can, and now use 3 whole cans for 3 Motorcycle's   T.P.
« Last Edit: October 22, 2012, 08:40:19 PM by T.P. »  Report to
LinnB
VRCC #25552
Arnold, MO
« Reply #15 on: November 21, 2012, 09:26:42 AM »
I got into a habit 6-7 years ago with my first Valk ('98 Standard) of putting a whole can of Seafoam in the tank once a month and am now doing the same with my '99 Interstate.
About 2 months prior to winter storage I put in a can with about with every other fill-up in antipation of the bikes sitting for 3-4 months.  So far I've not had a fuel or carb related problem but both bikes are low mileage compared to some other members (40k on Standard, 65k on Interstate).
It may be overkill but every spring they start up with 2-3 cranks of the starter and are ready to go    Smiley
« Last Edit: November 21, 2012, 09:30:35 AM by LinnB » Logged
miscott
Keep the rubber side down and hang on tight!
So. Central Kansas
« Reply #16 on: November 22, 2012, 02:22:44 PM »
OK, so where can one get this mysterious miracle product called Seafoam?
I've checked the websites of both O'Rielly's & Autozone. Not listed on either one, so I'm thinking they don't carry it.
Where do you guys get yours?
Also, speaking of Winterizing the Valk, do you guys recommend using a Battery Tender, or is it just easier to go out to the garage periodically and fire up the ol gurl and let her run awhile?
« Reply #17 on: November 22, 2012, 02:27:47 PM »
Our Auto zone has it, so does our other parts store. Our Farm store and walmart also has it. Farm store also has it by the gallons. I have not used a tender nor do I ever plan on it. I put stabilizer in her and put her to bed from Nov to March/April. Fires every time. I use to run it a few times a winter but have not the last 7 yrs or more. Our winters range from -10 to 40. Unheated detached garage.
« Last Edit: November 22, 2012, 05:50:42 PM by fudgie » Logged
« Reply #18 on: November 22, 2012, 04:00:07 PM »
FWIW, use a battery tender. Starting your bike may have some negative side effects, like running it rich, condensation accumulating in the mufflers, etc. if you run it, I would definitely get it warmed up before turning it off again.
My rides:
Bone
« Reply #19 on: November 23, 2012, 04:19:01 AM »
We have cold winters in s. Michigan. I always pull the battery and put it in the basement of the house. I check the charge once a month it holds pretty steady. Cold storage lowers the charge.
Stabil works for me the bike starts after 2-4 cranks. Before you buy the bottle hold it up and look at the contents. I think some people have bought bottles that sat on the shelf left over from previous seasons.
NITRO
Eau Claire, WI
« Reply #20 on: November 23, 2012, 04:47:59 AM »
O'Reilly's has it, that's where I got my last can.
