February 06, 2026, 02:24:58 AM *
Author Topic: Stupid question of the day about vaccuum plugs  (Read 1905 times)
doubletee
VRCC # 22269
Fort Wayne, IN
« on: November 20, 2012, 04:37:34 AM »
I purchased a Golan petcock and plan to replace the OEM vaccuum operated one this weekend. With what do I plug the vaccuum opening at the other end of the tube that connected to the OEM petcock? Do auto parts stores sell something specific for the job?
« Reply #1 on: November 20, 2012, 04:56:43 AM »
All I could find at AutoZone and Advance were these little packets of assorted thin vinyl brightly
colored vacuum plugs. I put on the tightest ones that would fit and then put the next size on too.
I ordered the OEM plugs from Honda, but the "crummy" ones are still on there years later, they
seem still good. Even though they seem good, I still didn't trust them, so recently I cranked the
bike and sprayed wd40 on them, expecting that if they were leakers the rpms would change,
but they still seemed vacuum-tight.
People take an inch-long (or so) bit of vacuum hose with a bolt silicone-sealed in the end on there
and I bet that works great.
« Reply #2 on: November 20, 2012, 04:57:20 AM »
I’m not familiar with the Golan, but if your asking about the hose that runs from the petcock to the #6 carb intake, that’s what provides the vacuum for the OEM petcock.  If your replacing the petcock and don’t need the vacuum any longer, just plug the intake stub with a cap like the ones on #1 or #2, or make your own from the hose you remove with a piece about 1 ½” long and a screw in the end.
Farther
Quimper Peninsula, WA
« Reply #3 on: November 20, 2012, 05:44:45 AM »
Get the plugs from Redeye.  http://redeye.ecrater.com/p/3301919/three-vacuum-caps-viton-b-version-5
~Farther
doubletee
VRCC # 22269
Fort Wayne, IN
« Reply #4 on: November 21, 2012, 07:37:19 AM »
Thanks to all for putting up with my ignorant question. Just ordered the Redeye plugs.  cooldude
Madmike
Campbell River BC, Canada
« Reply #5 on: November 22, 2012, 05:15:01 PM »
golf tee in teh hose should work for now..
« Reply #6 on: November 23, 2012, 05:29:42 AM »
I have some good plugs on for now......However, if they wear out I will not be replacing them.  Its much better to remove the nipple (it unscrews) and go buy some little bolts and screw them in. Thats my plan since I dont really want to desmog it  cooldude
Farther
« Reply #7 on: November 23, 2012, 10:01:01 AM »
Its much better to remove the nipple (it unscrews) and go buy some little bolts and screw them in. Thats my plan since I dont really want to desmog it.
I wonder why this is not done more often instead of replacing the rotted plugs.  The only down side I can think of would be for syncing the carbs and then the original nipples could be re-installed and later replace by metric machine screws. Brass metric machine screws would work very well if a source could be located.
~Farther
YoungPUP
Valparaiso, In
« Reply #8 on: November 25, 2012, 05:08:21 PM »
Found metric allen cap screws at the local menards ( big box hardware store) smeared then with a little permatex and screwed them in.  Pass the  carb cleaner leak test all day long.
99 STD (Under construction)
« Reply #9 on: November 25, 2012, 05:13:14 PM »
Yea would turn a 20 min carb sync into a all day job!  Cheesy
« Reply #10 on: November 25, 2012, 08:17:24 PM »
All day........takes all day to remove 6 screws one at a time........lets see I have had my bike almost 11 years and not yet sync'ed the carbs.......so, its not like it needs done every other week  coolsmiley
