February 06, 2026, 02:25:25 AM *
Author Topic: Final Drive Service  (Read 1539 times)
hoosier jaybird
NE IN.
« on: November 25, 2012, 11:42:09 AM »
I looked with horror at the final drive thread about splines that had destroyed themselves, so I went to Shop Talk to look how to service the drive assembly. I am abit confused about using a moly grease as well as another grease as well to lube the spline assembly. Is there a combination grease or does 1 go in first and then the other on top of the first? Moly(Guard Dog) and Lucas grease.
« Reply #1 on: November 25, 2012, 11:55:43 AM »
Me personally I just use grease, Valvoline, on all my parts. I have used paste before but this grease has been fine my last 50k miles. 77k on it now and it looks like new. Well I think it does, wont know till spring maybe.
« Reply #2 on: November 25, 2012, 11:59:45 AM »
You can use Guard Dog Moly paste, or the Lucas grease or Belray Waterproof.  I like to burnish a little moly paste into freshly cleaned metal (just a tiny bit since the Moly actually goes into the pores of the metal.  THen slather a healthy coating of a good heavy duty waterproof grease over the top of that.
Many just use the water proof grease or just use the guard dog.  I find the moly grease dries out more than the waterproof stuff.
Bottom line the grease itself isint as important as it staying in there.  Water will wash  out a weak grease.
re-doing it every 10K miles or so seems to be the best  insurance.
Hope that helps
9Ball
« Reply #3 on: November 25, 2012, 12:00:05 PM »
Do you have the Honda Service Manual?  Follow the manual's lubrication recommendations (moly paste and grease where specified), replace the 3 o-rings, and use assembly instructions following the rear wheel installation and you will have no worries...
Good luck.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
hoosier jaybird
NE IN.
« Reply #4 on: November 25, 2012, 12:21:53 PM »
Thanks guys,  this bike is new to me. I'm trying to head off problems. Any advice given is appreciated. It's a 99 with less than 18k, but concerned about age deterioration.
« Reply #5 on: November 25, 2012, 01:37:02 PM »
Iffin you know which end of a wrench to hang onto then all you need now is this board and a maintenance manual. You keep that rear end up and you WILL be saving huge $$$$$$ by keeping it up. Normal maint goes a LONG way on our Phatt Ladies. I have a Honda and a Clymer service manual and the fine folks on this board. My Honda dealer is flirting with $70.00 an hour mechanic rates. Dat buys a LOT of gasoline which = more ridin.  cooldude RIDE SAFE.
« Reply #6 on: November 25, 2012, 01:55:18 PM »
Just in case you didn't know, Dag's site has the service manual available for a free download.
http://www.valkyrienorway.com/download.html
My rides:
hoosier jaybird
NE IN.
« Reply #7 on: November 25, 2012, 04:27:31 PM »
Hey guys, thanks for the info and the link to the service manuals. This should all help. Now just a few more days to ride would be the checkers.
