February 06, 2026, 02:25:25 AM
Wiring question
Topic: Wiring question (Read 1076 times)
ragincajun
Atascocita, TX
Wiring question
November 25, 2012, 04:09:03 PM »
Two items I know I will want to add are a gps mount and a 12v adapter to allow me to plug in a phone or iPad charger.
What is the best way to wire these into the Valk?
VRCC Member #34758
Re: Wiring question
November 25, 2012, 04:14:47 PM »
just plug into the accessory hookups. 5A keyed circuit should handle what you said you wan it for. Under the right side cover. Look for the two unused wires in a plastic proctector (tube thinggy) Be careful removing the side cover its easy to break the tabs. It doesnt open like a door
YoungPUP
Valparaiso, In
Re: Wiring question
November 25, 2012, 05:00:48 PM »
Use the accessory leads to trigger a Relay to feed an add on fuse block of your preference. Then add accessories to that. Best and safest way to do it.
99 STD (Under construction)
