November 25, 2025, 03:03:04 PM *
Author Topic: Rear Drive Flange  (Read 1037 times)
Mase
# 518
« on: November 26, 2012, 03:27:17 PM »
Was it determined the the Gold Wing flange will work on the Valk?
« Reply #1 on: November 26, 2012, 03:38:18 PM »
1500 gold wing is the same, except for two years, 88 and 89 (I think these two years are correct).
The two years that won't work have 6 posts instead of five on the flange. I have a 1500 wing flange
right here to look at. And I know where a few with very minimal wear can be had for $20 or $25...
minimal = I wouldn't use it with perfect final drive splines, they'd be worth a new flange.
FryeVRCCDS0067
Brazil, IN
« Reply #2 on: November 26, 2012, 07:10:18 PM »
Are the hub splines the same as ours on the 88's and 89's with just the flanges being different on those years?
I'd sure like to get one of those $25 hubs you mention.
« Reply #3 on: November 27, 2012, 08:35:28 AM »
I got a flange from the trike guy for $25. I got the wing final drives for $75, almost too much, but
since I received a bad final drive when I tried to buy it off eBay, I figgered holding it in my
hand and inspecting it before I bought it was worth it.
The trike guy said something that made me think that a five-fingered flange would fit
into a hub made for a six-fingered flange, but even if that is true, it doesn't mean that
the pressed-out splines of a six-fingered-flange-hub  coolsmiley would be right for us.
EDIT: I just verified that the part number for the 88 wing ring gear is the same as for a
98 wing ring gear, so I'd say - they'd work fine...
See this flange? It is on my bike now. See down in the splines on the left side how the spline
edges look shiny? I bet this flange wouldn't pass the "click test" that the trike guy and I invented
the other day when we were looking through his pile of flanges. I bet  he has some flanges that
are as good, or pretty-much-as-good as this flange. I'm thinking of going back over there and
getting one or two more wing final drives if I can find ones that look like they have good splines.
I might pick up some flanges too. Some of the flanges he has I wouldn't want to use, don't know
whether it is just a few or most of them... I was real picky when I there the other day, and only
took the flange we found that seemed to have no wear at all..
