November 25, 2025, 04:32:02 PM *
Author Topic: Valk Carbs  (Read 1204 times)
glassguy
« on: November 30, 2012, 07:22:54 AM »
I have the opportunity to pick up a set of valk carbs for $100.  The price seems right but what will it cost to go through them and replace everything that needs replacing?  I would be looking to bring them to original specs like new if possible.  I looked on Honda Line and it appears that if the right parts have gone wrong, I might spend $100 or more per carb to rebuild them.  could this be or am I just not reading the parts page correctly?  Thanks in advance, G
ryord
« Reply #1 on: November 30, 2012, 07:45:18 AM »
You can buy a carb rebuild kit from Redeye tech he should have the kit for all six carbs for around 65.00 if you do it yourself.
 http://redeye.ecrater.com/p/2063876/carburetor-o-ring-kit-viton-gf
« Last Edit: November 30, 2012, 07:47:41 AM by ryord » Logged
Dorkman
San Carlos, CA
« Reply #2 on: November 30, 2012, 11:22:09 AM »
Looks like a good investment if you are confident about doing the work.  If you never need the carbs yourself, I'm sure you could sell them at a profit to someone with a gummed up bike that has been sitting too long.  Or you could save them for another board member...   Smiley
Poor Ol Harry
Baytown,TX. East of Houston
« Reply #3 on: November 30, 2012, 01:09:13 PM »
The $65.00 is the correct cost to do the carbs,BUT I choose to r&r all 6 needle (float) valves as well. I located some for 15 dollars each or so dollars ,but was advised to go to Honda & get the better ones @ $30.00 each & I did.Juat elimated another "IF"......I'd gladly give $100.00 for them if nothing else to lay on the bench & practice rebuild with.
9Ball
« Reply #4 on: December 01, 2012, 05:24:12 AM »
The cost depends on whether the carbs need things like new diaphragms, floats, and float valves.  If you have to replace these then your estimate of $100 per carb isn't far off.  These items are very expensive and add up to big $$ quickly.
If you're just replacing o-rings, fuel and drain tubing, and jets then $100-150 for the whole project should get you a nice spare carb bank.  This is about how much I've spent on my spare carbs but I chose to get the OEM drain tubing, fuel lines, and vent tubing and replaced all the JIS bolts with hex head bolts.
Good luck with your project.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
