ricoman
« Reply #1 on: December 01, 2012, 09:21:50 AM » |
don't wire anything without using a relay there is good info in this post http://www.valkyrieforum.com/bbs/index.php/topic,8908.0.htmland a link to wiring a relay stock horn switch/wires won't stand up to big or multiple horn use
98 Tourer, black and chrome, added 8/11/10 98 Std, yellow/cream, totaled 8/3/10
BIG--T
The Twilight Zone
« Reply #2 on: December 01, 2012, 09:26:56 AM » |
Sigrún
« Reply #3 on: December 01, 2012, 11:38:13 AM » |
IBA #54465
« Reply #4 on: December 01, 2012, 02:08:04 PM » |
+1
« Reply #5 on: December 01, 2012, 02:09:43 PM » |
This is where I mounted my Stebel.  Made a simple bracket from a scrap piece of alum. flat bar.
I can't help about the shape I'm in I can't sing, I ain't pretty and my legs are thin But don't ask me what I think of you I might not give the answer that you want me to
BIG--T
The Twilight Zone
« Reply #6 on: December 01, 2012, 05:04:42 PM » |
Thanks man, just what I needed!
BIG--T
The Twilight Zone
« Reply #7 on: December 01, 2012, 05:19:28 PM » |
Thanks guys for all the help. I just have one question: I plan to run the Bad Boy with the relay and the same procedure with the 2 electric horns. My question is can I tie them all to the 2 original horn wires and use horn button? Thanks
PhredValk
« Reply #8 on: December 01, 2012, 05:40:21 PM » |
Power a relay directly from the battery with a fused wire (or from a secondary fuse panel wired to the battery thru a fuse and relay). Wire the 'trigger' on the relay to the positive horn wire and the output from the relay to as many horns as you want. The 'trigger' uses very little power, so the existing horn wire is plenty. The horn button will now blow them all. Fred.
« Last Edit: December 01, 2012, 05:46:43 PM by PhredValk »
BIG--T
The Twilight Zone
« Reply #9 on: December 02, 2012, 03:59:51 AM » |
Thanks Fred, I'm understanding it better now, It's easier than I thought. Yes I'm pulling straight off the battery using an inline fuse going to my relay. Thanks, Tony
« Reply #10 on: December 02, 2012, 04:55:19 AM » |
I found this picture very helpful...   -Mike
rayvin57
« Reply #11 on: December 02, 2012, 06:18:30 AM » |
A great source for m/c elec. supplies is Eastern Beaver (I know, great name). I used a PC-8 fuse panel with relays on my Rocket III to power horns, lights, gps, audiovox cruise control, power outlet, etc. Great products, fast shipping. Made adding additional stuff a breeze and kept the battery from having a zillion wires running to the terminals. http://www.easternbeaver.com/Main/Wiring_Kits/Fuseboxes/PC-8/pc-8.html
BIG--T
The Twilight Zone
« Reply #12 on: December 03, 2012, 06:12:53 AM » |
Thanks guys for all the help!
