November 25, 2025, 04:32:20 PM *
Author Topic: Finally Changed My Intake O-Rings  (Read 1309 times)
indybobm
Franklin, Indiana VRCC # 5258
« on: December 03, 2012, 03:03:10 PM »
I finally got around to changing my intake o-rings today. I noticed an increase of the yellowish-brown sludge around the base of no. 3 intake. Out of curiosity, I wanted to see just how smashed the old o-ring were. Carefully measuring them with my digital mics, the old o-rings measured .182mm thick. The new o-rings measured .246mm. Quite a difference. The old ones really looked flat. It did not appear that the o-rings on the left bank had been changed before. All of the leakage that I noticed was on the right bank, namely no 1 & 3. The substance leaks out of the outer part of the o-ring. That seems strange since; 1. there is a vacuum in the intake tract, and 2.  when on the stand stand that point is higher. No difference in how it runs, no problem there. I got tired of wiping it up. I'm sure it would have caused a problem eventually.
So many roads, so little time
VRCC # 5258
« Reply #1 on: December 03, 2012, 03:17:40 PM »
What is that yellow-ish brown stuff........corn oil?
I've been noticing that same kind of crap on my sparkley polished Grumpy's tips too.  Wipes off with some Windex or other cleaner easy enough though.
I also need to change mine as well.  Have the rings, just need to get one of those round tuits.
NITRO
Eau Claire, WI
« Reply #2 on: December 03, 2012, 05:05:22 PM »
It's fuel/air mixture, isn't it? Nothing else should be passing through those tubes. On the three valks I've done, the gaskets leaked the same on both sides, more as you moved back.
When in doubt, ride.
saddlesore
« Reply #3 on: December 03, 2012, 05:36:38 PM »
   I ordered some o rings a couple of days ago.  The no. 2 is the only one leaking yet.
   I'm assuming that the burning oil smell when I stopped was that.  No other signs of leaking oil.
  First time changing  the rings in 102,000 miles.
DARE TO BE DIFFERENT
YoungPUP
Valparaiso, In
« Reply #4 on: December 03, 2012, 05:40:30 PM »
Leaking intake orings shouldnt give you a bunring oil smell.  Maybe a leaky shifter seal?
99 STD (Under construction)
Steve K (IA)
Cedar Rapids, Iowa
« Reply #5 on: December 03, 2012, 05:56:06 PM »
You have a source for the o-rings?
States I Have Ridden In
saddlesore
« Reply #6 on: December 03, 2012, 06:02:35 PM »
http://redeye.ecrater.com/c/414983/carb-intake-seal-kits
That should get you there.
saddlesore
« Reply #7 on: December 03, 2012, 06:10:29 PM »
I never saw any oil leaking there. A while back I had a leak from the oil pressure sensor. That was an easy fix with a little teflon tape.  The only time I notice it is when I pull into the garage. Never shows a loss of oil between oil changes.
« Reply #8 on: December 03, 2012, 06:33:10 PM »
I get mine here.....
http://www.carolinabikeandtrike.com/ORings.htm
