February 06, 2026, 04:19:05 AM *
Author Topic: fairing brass insert fasteners???  (Read 1545 times)
rocker333
« on: December 05, 2012, 11:50:25 AM »
I have my Interstate fairing apart now and need some of those 5mm brass screw inserts that hold the speaker panels on the fairing...
Does anyone have a source for the brass inserts???
thx, rock
« Reply #1 on: December 05, 2012, 12:47:34 PM »
Clean them up and reuse them.
Use some type of epoxy or something like that to fix them tight again.
« Reply #2 on: December 05, 2012, 12:55:42 PM »
I had the same problem except 4 of mine broke and 3 others just fell out. The 3 unbroken ones got epoxy and put back in and the other 4 are still missing. Looked in several hardware stores and cant find anything like them. I have started to use anti seize on the screws. I would also like to know where to get these.
Michvalk
Remus, Mi
« Reply #3 on: December 05, 2012, 01:01:51 PM »
You could still get them from Honda last year. Try HDL or your local cooldude
rocker333
« Reply #4 on: December 05, 2012, 01:10:08 PM »
A couple of mine broke... the others I used JB weld to hold them...
I have searched all the websites that have the Honda microfiche for OEM parts...
I was able to get the 5mm screws that go in the brass inserts...
I have a guy at Tulsa Honda searching for them now...
rocker333
« Reply #5 on: December 05, 2012, 02:06:48 PM »
The Honda shop just told me you can't buy these inserts separately...  tickedoff
screw honda... time to make it better...
« Last Edit: December 05, 2012, 02:10:14 PM by rocker333 » Logged
« Reply #6 on: December 05, 2012, 02:10:03 PM »
What ya got to buy?    The whole fairing?
rocker333
« Reply #7 on: December 05, 2012, 02:15:36 PM »
Yep... or buy the chrome headlight trim $50, that'll get you 5 inserts... or the windshield trim $50, 4 on it... better than buying the cowl $700...  crazy2
« Reply #8 on: December 05, 2012, 02:19:45 PM »
part number 90316-MJ1-000
$2.50 each from HDL
rocker333
« Reply #9 on: December 05, 2012, 02:48:45 PM »
$2.50 each from HDL
THANK YOU SIR !!!!
« Reply #10 on: December 05, 2012, 03:59:40 PM »
Send me a PM (your address) and I'll send some to you. I replaced an I/S fairing a few years ago and saved the inserts.
Joevalk
Santa Fe, Texas
« Reply #11 on: December 05, 2012, 05:37:34 PM »
A few of mine fell out, I epoxied them back into place. I found some small o-rings that fit around the screws and went back together with it.  This helps tighten it up and helps all the rattling. A Hayhauler to me that trick. It worked cooldude    Oh yeah, use anti-seize on the screws too.
VRCC#32720
1999 Grn/Silver Interstate
rocker333
« Reply #12 on: December 05, 2012, 08:59:17 PM »
Thank you very much for your offer but I ordered some today from HDL... so I'll be in good shape soon!
Thanks again, rock
da prez
Wilmot Wi
« Reply #13 on: December 08, 2012, 08:30:28 AM »
  This is far from stock , but there is a thing called a cable stop that is made of brass. It usually has a hole drilled , as for a choke cable and a screw to stop the cable. They are available at most hardware or lawn equipment stores or farm supplies. If you need larger sizes , a truck or equipment dealer will have them.
                             da prez
