February 06, 2026, 06:12:15 AM *
Author Topic: valve adjusting  (Read 1575 times)
fubar606
eastern washington
« on: December 27, 2012, 07:57:55 PM »
well i finally did my first valve adjust on my 2000 fat girl I/S . man after doing all of my vtx1800 adjusting this was a breeze.  all was fine except #1'#3'#6 exhaust they were a little lose.
 all back together and no leaks. i did notice that the radiator was not tight to the frame is it supposed to move a little didn't see any where to tighten it up. cooldude
life is sexually transmitted and always fatal
Oklahoma_Valk
Central OK
« Reply #1 on: December 27, 2012, 08:39:08 PM »
Mine wiggles too. Bugs me. Oh well.
-Safe winds
Let those who ride decide.
97Valk_CT_Euless
Euless Tx
« Reply #2 on: December 28, 2012, 01:02:38 PM »
Just had my radiator off. Only way I can see to tighten is to replace the bushings. Only the top bolt (behind the fork-lock) holds it on, the other two pins had threads but no nuts. I think it's per-design.
Nuts there wouldn't tighten it and the right side would be nearly impossible to tighten anyway.
rayvin57
SW Florida
« Reply #3 on: December 28, 2012, 03:20:37 PM »
I'm with 97Valk--it's the design.  If the fit is really sloppy, new bushings are probably in order.
fubar606
eastern washington
« Reply #4 on: December 28, 2012, 10:22:15 PM »
after i put the pods back on it helped quit a bit. it took about half the shake out of it
« Reply #5 on: December 29, 2012, 05:21:13 PM »
+1  cooldude
My rides:
