February 06, 2026, 06:12:39 AM *
Author Topic: rebuilt tensioner update  (Read 2732 times)
Brian
Monroe, NC
« on: December 30, 2012, 04:30:30 AM »
I had rebuilt this unit and needed to give it a try. So one rainy Saturday I installed it. I now have over 1,000 miles on it with no issues. Good luck rebuilding your old tensioners.
97Valk_CT_Euless
Euless Tx
« Reply #1 on: December 30, 2012, 05:47:33 AM »
Nice work! The more I read on the subject the more I wish I'd done this instead of new oem's. The oem pulleys stamped diameter doesn't seem nearly as belt-friendly as this looks. Now for life the replacement cost is $20, or less.  Not to mention being able to pick one up in a hurry at a local parts house if you get in trouble.  I plan on owning more Valk's, but I don't plan on ordering any more tensioners from Honda! I'll be rebuilding mine next payday, just as a little rebellion against mother Honda!!!
RickMXZ
« Reply #2 on: December 30, 2012, 05:52:58 AM »
Details please, that looks great. I know the posting says update but I didn't see the original.
Bone
« Reply #3 on: December 30, 2012, 06:20:34 AM »
RickMXZ try this link for the original post.
http://www.valkyrieforum.com/bbs/index.php/topic,46686.0.html
RP#62
Gilbert, AZ
« Reply #4 on: December 30, 2012, 08:08:55 AM »
What's the best method for getting the stock one apart?
-RP
97Valk_CT_Euless
Euless Tx
« Reply #5 on: December 30, 2012, 08:38:39 AM »
I found this link doing a search on gl1500 tensioner. The guy did a great write up, though he went a bit overboard. Took ALL the fun out of it. He did a heckuva lotta research.
http://www.sdb-e.com/TENSIONER/TENSIONER-REBUILD-JCS.pdf
Westsider
Fort Worth TX.
« Reply #6 on: December 30, 2012, 09:49:31 AM »
Excellent write up, post's , looked up on HDL , $70.68 for that little spinner.. cooldude
Brian
Monroe, NC
« Reply #7 on: December 30, 2012, 05:58:40 PM »
Yep, this is the article that I used to get ideas. Using the flat head meteric bolt seemed to be the easiest for this bearing. There really isn't alot of belt pressure running on these. I chose this bearing because it has a large mounting surface that will keep it tight against the backing plate.
Brian
Monroe, NC
« Reply #8 on: December 30, 2012, 06:05:33 PM »
-RP
RP, 97valk_CT here has the goldwing article link here. Drill press and I think I used a 1/2" bit to drill the middle out of the mounting stud from the back of the mounting plate. I then used a dremmel to remove the rest of the material till it feel out. Becareful if you try to pry or twist it out, the back plate will bend. I did that and had to straighten it flat again before assembling it.
RP#62
Gilbert, AZ
« Reply #9 on: December 31, 2012, 07:26:08 AM »
-RP
Great.  Thanks Brian.
-RP
