February 06, 2026, 07:45:04 AM *
Author Topic: Rear Wheel/Final Drive/Drive Flange problem  (Read 3990 times)
Xtracho
The Bosses
Florida's Emerald Coast
« on: December 31, 2012, 10:12:19 AM »
While I'm home I'm installing a new rear tire and servicing the rear end/final drive using ChrisJ's excellent PowerPoint presentation. This morning when I removed the wheel the drive flange did not separate from the final drive with the wheel. The PO told me he had never serviced the rear end/final drive and I'm guessing that has something to do with it. Anyhow, I need some sage advice on how to separate that flange from the final drive unit so I can get to the O-Rings and such. Plus, it will make getting the wheel to mount back on a lot easier. Any ideas or tips will be greatly appreciated.
Mark
In the stable:
'84 GW Aspencade
'47 Indian Chief
'98 Valkyrie
Valker
Wahoo!!!!
Texas Panhandle
« Reply #1 on: December 31, 2012, 10:23:03 AM »
Slowly apply pry bars.
9Ball
« Reply #2 on: December 31, 2012, 10:28:06 AM »
remove the dust cover first and don't pry against it or you will damage the plastic.  There's a slot at the bottom that will allow a screwdriver or pry bar to be inserted.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
CajunRider
Broussard, LA
« Reply #3 on: December 31, 2012, 10:43:23 AM »
That is a fairly normal issue, so don't freak out about it.
As others said, you can pry it out with a screw driver.  Just be careful not to damage the plastic ring.  There is a slot (in the plastic ring) for that reason, making it easier to get off before you try to remove the rim (for future reference).
Go slow and take it easy.  It'll come out after a bit of staring at it, working on it, and a beer or two.   cooldude
Good luck!! You'll get it out of there!
Don't forget to grease it well before you put it all back together.
Sent from my Apple IIe
Xtracho
The Bosses
« Reply #4 on: December 31, 2012, 10:52:00 AM »
Thanks guys! Got it after removing the plastic dust ring and prying with a screwdriver and claw hammer. Jeezus! Dry as a bone and just as rusty. No wonder that flange stayed with the final drive when I took the wheel off. Fortunately the splines, male and female, look good. Driveshaft, pinion cup and drive all have good grease still on them. So it's off to Lowe's for some wire brushes to clean the corrosion off the splines, lube em up with Moly and get that new tire on.
Thanks again for your help!
Mark
In the stable:
'84 GW Aspencade
'47 Indian Chief
'98 Valkyrie
« Reply #5 on: December 31, 2012, 11:35:28 AM »
Good Job  cooldude  Just dont get in a hurry and tighten down the 4 final drive nuts before you torque the axle nut and you will be fine.
Glad the PPT helped!
Xtracho
The Bosses
« Reply #6 on: December 31, 2012, 02:08:05 PM »
It was great Chris. I d/loaded while I was in Rio anticipating doing this when I got home. Yeah. I do the same with my 'Wing. The last nuts to get torqued are the 4 on the final drive. Thanks for the PPT!
Mark
In the stable:
'84 GW Aspencade
'47 Indian Chief
'98 Valkyrie
Grumpy
Tampa, Fl
« Reply #7 on: December 31, 2012, 04:07:42 PM »
I think you have that reversed, torque the axle first, then tighten the 4 final drive bolts, that is the proper procedure according to the Honda Manual. Other wise, you can miss align the assembly and cause accelerated wear.
« Reply #8 on: December 31, 2012, 06:41:41 PM »
Another point. You mentioned moly. Just get Bel Ray waterproof grease. Lucas EP #2 also is good stuff. Hondas moly paste doesn't last.
« Reply #9 on: December 31, 2012, 07:10:44 PM »
I guess its how you read it.........DONT GET IN A HURRY (and make the mistake of) tightening the 4 bolts before you torque the axle...........
JWV 99 I
« Reply #10 on: December 31, 2012, 07:26:43 PM »
I currently have the rear tire and wheel off of my Interstate, I am unable to loosen the four bolts on the final drive.  I have soaked with WD 40 for a couple of days and still can not get them loose.  Any recommendations would be appreciated. Thanks in advance.
Steve K (IA)
Cedar Rapids, Iowa
« Reply #11 on: December 31, 2012, 07:33:57 PM »
 cooldude on the BelRay waterproof grease.
States I Have Ridden In
« Reply #12 on: December 31, 2012, 07:46:42 PM »
Use a breaker bar.
Xtracho
The Bosses
« Reply #13 on: December 31, 2012, 11:20:11 PM »
I've got a tub of the BelRay waterproof. Are you saying to use that on the splines instead of the Moly?
Mark
In the stable:
'84 GW Aspencade
'47 Indian Chief
'98 Valkyrie
X Ring
VRCC #27389, VRCCDS #204
« Reply #14 on: January 01, 2013, 12:43:45 AM »
Lots of guys do.  Just make sure you perform maintenance regularly.
Marty
Xtracho
The Bosses
« Reply #15 on: January 01, 2013, 04:58:51 AM »
Marty
I thought about lightly coating the splines with the Moly then topping it all off with the Belray.
Mark
In the stable:
'84 GW Aspencade
'47 Indian Chief
'98 Valkyrie
« Reply #16 on: January 01, 2013, 05:31:25 AM »
Marty
That idea is a good one, no problem with that, I do it, its right on the PPT I just use a different waterproof grease but its essentialy the same thing
Xtracho
The Bosses
« Reply #17 on: January 01, 2013, 05:45:58 AM »
Kind of scary that I rode that bike all the way from St. Louis to PCB with that gear as dry as it was.
Mark
In the stable:
'84 GW Aspencade
'47 Indian Chief
'98 Valkyrie
« Reply #18 on: January 01, 2013, 06:29:02 AM »
Im glad you found and corrected it before serious damage was done.  Keep an eye on it now....bout every 10-12K unless you dont get much more than that out of a tire.  I get 20K+ so I break it down once half way through the tire
Xtracho
The Bosses
« Reply #19 on: January 01, 2013, 07:48:23 AM »
Thanks Chris. All cleaned up now and just waiting for my tire guy to open tomorrow to mount the tire then I'll put it all back together. Then off to get new front/rear OEM brake pads. Those EBC pads on the front buzzing when applied drives me nuts! I've got 3 round trips PCB to Louisiana and one to St. Petersburg to make this month. So I want everything good before I leave. Rest of the day is dedicated to cooking for the girls and......drum roll please....football!
« Last Edit: January 01, 2013, 07:50:11 AM by Xtracho » Logged
Mark
In the stable:
'84 GW Aspencade
'47 Indian Chief
'98 Valkyrie
« Reply #20 on: January 03, 2013, 08:04:52 AM »
JWV,, Just double-up your wrenches. Or, give the wrench a rap with a hammer. A sudden 'shock' will usually break things loose.
« Reply #21 on: January 03, 2013, 09:12:35 AM »
I'm surprised that you were able to get the wheel out from the swingarm without taking the drive flange with it.
I was thinking it is next to impossible - just not enough room.
You must have pried it like crazy!
Xtracho
The Bosses
« Reply #22 on: January 03, 2013, 09:16:04 AM »
It was tight and with some strategic wiggling and some choice descriptive language it came on off.
Mark
In the stable:
'84 GW Aspencade
'47 Indian Chief
'98 Valkyrie
JC
The Beast
Franklin, TN
« Reply #23 on: January 03, 2013, 01:06:26 PM »
Let me recommend that you also check the shock bushings for wear. They can really affect the handling if they're worn, and are cheap to replace.
« Reply #24 on: January 03, 2013, 02:20:29 PM »
Some have had to unbolt the final drive and remove the drive attached to the wheel all at once, just another option
KSDragonRider
Salina, KS
« Reply #25 on: January 03, 2013, 04:54:08 PM »
This is actually my preferred way of doing it. it is all coming out anyway, and it is just easier to get it apart with it out from under the bike.
Dalen & Shay -> Salina, KS
VRCC Member #33950
Xtracho
The Bosses
« Reply #26 on: January 03, 2013, 05:06:13 PM »
Interesting. Maybe something to try next time around.
Mark
In the stable:
'84 GW Aspencade
'47 Indian Chief
'98 Valkyrie
