February 06, 2026, 07:46:22 AM *
Author Topic: Cleaning Clear Coat Wheels  (Read 2483 times)
Xtracho
The Bosses
Florida's Emerald Coast
« on: January 03, 2013, 07:00:08 AM »
What do you guys/gals use to clean your wheels? While I've got everything torn down I want to clean them up good. I must admit for selfish reasons. I'm headed to the office in Louisiana for a class on Monday. This will be my first ride over since I got the phat lady. Three of the instructors have Harleys and give me grief about my GoldWing. Now I'm gonna show up and show them up!  Smiley
Mark
In the stable:
'84 GW Aspencade
'47 Indian Chief
'98 Valkyrie
Momz
ABATE, AMA, & MRF rep.
« Reply #1 on: January 03, 2013, 07:12:46 AM »
If your wheels are clear coated, then just use soap and water with a soft cloth or a special "Mag Wheel Brush".
You mentioned a GoldWing, but if your refering to a Valkyrie, only the 2001-2003 have clear coated wheels.
!997-2000 Valkyries do not have clear coat and are subject to corrosion, and with out proper maintainence, they get "real ugly....real fast".
ALWAYS QUESTION AUTHORITY!
Xtracho
The Bosses
« Reply #2 on: January 03, 2013, 07:18:48 AM »
OK...I was under the misconception that my Valk had clear coated wheels. Since that is not the case any good wheel cleaner should do? Thanks!
Mark
In the stable:
'84 GW Aspencade
'47 Indian Chief
'98 Valkyrie
« Reply #3 on: January 03, 2013, 07:33:50 AM »
IMHO this is the best product for cleaning/polishing aluminum wheels (and all metals), a liquid, not a paste, works fast, and has a wax in the mix.  One small bottle will last a long time.
http://badtothebom.com/products?page=shop.product_details&category_id=6&flypage=flypage.tpl&product_id=20
Michvalk
Remus, Mi
« Reply #4 on: January 03, 2013, 02:03:47 PM »
Nothing says you DON"T have the clearcoated wheels. They are interchangable, so look them over before applying any stuff that would  damage the clearcoat. You should be able to tell the difference. The rim and some of the wheel will be shiney, and the center, near the hub is not. Hope this helps cooldude
Xtracho
The Bosses
« Reply #5 on: January 03, 2013, 02:43:39 PM »
Just to cover all bases I got some of Griot's Wheel Cleaner. Supposed to be safe on all wheel types.
Mark
In the stable:
'84 GW Aspencade
'47 Indian Chief
'98 Valkyrie
« Reply #6 on: January 03, 2013, 08:10:35 PM »
I used a Mother's mini powerball for polishing. With some work, they can look almost like chrome.
« Reply #7 on: January 04, 2013, 05:07:50 AM »
for a mirror/chrome shine on aluminum
www.topoftheline.com
http://www.topoftheline.com/alexpol.html
http://www.topoftheline.com/poal.html
Xtracho
The Bosses
« Reply #8 on: January 04, 2013, 05:15:36 AM »
What wax/compound/cleaner would you use with the mini-powerball?
Mark
In the stable:
'84 GW Aspencade
'47 Indian Chief
'98 Valkyrie
« Reply #9 on: January 04, 2013, 01:02:48 PM »
I use Meguires mag and aluminum polish and follow it up with Mothers Billett polish. I did my fork lowers starting with 800 grit (wet) then 1000 and 1500 before the powerball polishes.
