February 06, 2026, 07:45:03 AM
clutch basket nut size?
Topic: clutch basket nut size? (Read 1487 times)
Mr.BubblesVRCCDS0008
January 06, 2013, 01:08:44 PM »
Quick question. anybody know the size of the nut to unstack the clutch basket.? fixing to go buy one. either a 32 or 34 mm I think.
Bone
Re: clutch basket nut size?
January 06, 2013, 01:36:36 PM »
Put your question in the search bar and found several. I don't know which is correct I haven't done the job.
Re: Clutch Basket Lock nut size?
« Reply #1 on: January 25, 2012, 09:14:34 AM »
Reply with quoteQuote
Well after all night looking i finally found it, if anyone wants to know it is a 46mm 12pt. deep sockect or you could use a 1 13/16 12pt. deep socket, no the hunt for one of these sockets!!!!
January 06, 2013, 02:41:13 PM »
THat's the big nut that holds the outer drum to the engine shaft. THe nut I'm trying to removes is the one that holds the inner drum to the clutch pack. It's either a 32 or 34 mm I think, I had a 30mm too small and a 36mm too big. TIA
Valkpilot
What does the data say?
Corinth, Texas
January 06, 2013, 04:02:38 PM »
31 mm
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
chrise2469
Winnipeg Manitoba Canada
January 07, 2013, 11:52:49 AM »
Looked in the tool chest and my past thread on my clutch removal and its a 32mm.
January 10, 2013, 04:21:26 PM »
I ended up using a 6 point 1 1/4 in socket. I built a press on my work bench and broke it down today. After only 160,000 miles my rivets let go in the damper plate. All pieces were still in the fiction plate so no damage was done. If you have to do this job get a good quality set of snap ring pliers. The cheap mulit tip ones are junk. Waiting on parts now.
PSUbag
Huntingdon, Pa.
Reply #6 on:
January 12, 2013, 08:17:03 AM »
I hope you got a new clutch spring too. I didn't, the FIRST time
Reply #7 on:
January 12, 2013, 12:57:46 PM »
Mine checkout ok. We can only hope now.
