February 06, 2026, 07:54:45 AM *
Author Topic: Interstate Riser Fitment  (Read 1346 times)
NITRO
Eau Claire, WI
« on: January 16, 2013, 06:38:40 PM »
Does anyone know if these risers will fit the Interstate? I bought them quite a few years ago to use on my Standard, but didn't get around to putting them on. I now have an Interstate and am not sure that the large "heads" on the risers will work with the IS fairing. Any input would be appreciated.
Here is a pic of one of the risers:
When in doubt, ride.
« Reply #1 on: January 17, 2013, 05:47:16 AM »
I don't have them, but they should work with no problem.  It will only take a few minutes to mount them and see.  And turn the handlebars to the lock each way to check your wires/hoses for tightness.  You may need to turn the wire clips on the back of the handlebars *180, like is often done with taller risers.
NITRO
Eau Claire, WI
« Reply #2 on: January 17, 2013, 05:33:14 PM »
Thanks. I figured someone here must have tried them, they're pretty common risers. I'll just have to throw them on in the spring, I need to take the fairing off anyway.
Michvalk
Remus, Mi
« Reply #3 on: January 17, 2013, 08:03:44 PM »
Actually, you don't need to remove the fairing to change risers. But you do need to pad the gas tank heavily, to keep from denting the tank when you drop the clamp off. Don't ask how I know Grin cooldude
stude31
Topeka,ks
« Reply #4 on: January 21, 2013, 09:53:05 AM »
An extra set of hands sure does provide added insurance to not to the thinkable.  Cheesy
