February 06, 2026, 09:35:25 AM *
Author Topic: airbox mods  (Read 14856 times)
rocketray
« on: January 19, 2013, 03:42:01 AM »
I understand the valkyrie airbox is restrictive...how does one fix/modify it ?    I have a suzuki GSX 650f that was completely transformed with a 4 inch square hole cut in the top of it's airbox
fordmano
San Jose, CA.
« Reply #1 on: January 19, 2013, 05:02:26 AM »
I suggest you leave it alone, or atleast spend LOTS of time reading about modifying the air box.
Horror stories abound of failed attempts about heading down this path you have inquired about.
K&N air filter without pre-filter is about as open flow as you want, Honda really did a good job with this design.
« Last Edit: January 19, 2013, 05:04:03 AM by fordmano » Logged
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
« Reply #2 on: January 19, 2013, 05:05:25 AM »
I don't know where you heard bad things about the Valkyrie's air box... every
story I've heard is that nothing is better than an OEM unmodified airbox...
http://www.valkyrieforum.com/bbs/index.php?topic=25552.0
« Reply #3 on: January 19, 2013, 05:47:50 AM »
Not a good idea.  Hoser  Sad
Thunderbolt
Worthington Springs FL.
« Reply #4 on: January 19, 2013, 06:11:12 AM »
What they said.  cooldude  I don't remember any positive responses ever of modified air boxes.  I do remember one question on how to put it back to stock after it was modified.
SANDMAN5
Mileage 65875
East TN
« Reply #5 on: January 19, 2013, 06:26:59 AM »
I started to do it once....till I read the archives. Seems like VERY few
good things happened when the airbox was mutilated. I'd say leave
it alone...and thumbs up on the K&N with no prefilter. cooldude
« Reply #6 on: January 19, 2013, 06:54:26 AM »
Leave it alone !  Honda got it right.
Blackduck
West Australia
« Reply #7 on: January 19, 2013, 07:13:51 AM »
You mean like this?
Only go here if you have time,patience, money and more time
« Reply #8 on: January 19, 2013, 07:32:23 AM »
If you want troubles, muck with the airbox.
Too many of us have made mods and  then had to go find an unmodified air box to correct our screwing around.
So LEAVE it alone, it is far from being restrictive.
There is one alternative to messing with the air box, go BLOWER.
RP#62
Gilbert, AZ
« Reply #9 on: January 19, 2013, 07:33:01 AM »
The only thing I've ever heard that has been beneficial along these lines is shimming the front of the tank so it up a little higher.  This aids airflow to the box, but it seems to depend on the bike - doesn't make any difference on some.  As others have said though, have never heard of anything good coming from modifying the box.  The followup post is usually how do I repair my airbox.
-RP
« Reply #10 on: January 19, 2013, 03:36:48 PM »
-RP
  +1    I had to use a spacer when I installed a Supertank. Just wasn't getting enough airflow. 1/2" rubber spacer cleared up the problem.
« Reply #11 on: January 19, 2013, 03:54:45 PM »
see my posts.
http://www.valkyrieforum.com/bbs/index.php/topic,8248.0.html
1500Rider
« Reply #12 on: January 19, 2013, 04:01:06 PM »
Another +1 on the spacer at the front of the gas tank. Not worth messing with the airbox.
1990 Honda VFR750F
1997 Honda Valkyrie GL1500 Tourer
1998 Honda Gold Wing GL1500 SE
slider
mulberry arkansas
« Reply #13 on: January 20, 2013, 08:16:32 AM »
I found out not to mess with the air box....voice of  reason told me not to but I didnt listen--took a new air box to fix the problem .I drilled a few holes to increase air flow--I will never do anything to the air boxc again...
a proud navy veteran
F6BANGER
Albuquerque NM
« Reply #14 on: January 20, 2013, 08:36:31 AM »
If I was gonna modify the air box this is how I would do it..... cooldude Nitrous Oxide cooldude
Blackduck
West Australia
« Reply #15 on: January 20, 2013, 09:37:01 AM »
Current set up, been this way for a couple of years
Blackduck
West Australia
« Reply #16 on: January 20, 2013, 09:44:40 AM »
This was with the early cut out on the airbox, have not been back on the dyno to check the latesrt version.
« Reply #17 on: January 20, 2013, 09:46:46 AM »
  Has this modifacation improved or detracted from performance or M P G??  Just a lot curious.  2funny Yeah-i know-it killed the cat but i gots lotsa cats.  Cheesy RIDE SAFE.
Blackduck
West Australia
« Reply #18 on: January 20, 2013, 10:06:25 AM »
Improved performance, MPG remains about the same but does not drop off at high RPM.
As stated early not something anyone wants to take on without a lot of time, some money (dyno work) and a lot of patience.
As will be seen by the curves there is very little improvement at lower RPM.
Play at your own risk.
Cheers Steve
Hooter
S.W. Michigan
« Reply #19 on: January 21, 2013, 10:42:52 AM »
   Some may disagree but typically a rule of thumb: You can mess with the exhaust all you want. Mess with the air, rejet is a must. Things get lean if you modify this side of things and this where the rejet comes in, to fatten it up again.  2 cents.
rocketray
« Reply #20 on: January 21, 2013, 03:31:22 PM »
ok guys thanx     so if I have the viking headers and needles on already   cut the airbox to blackducks spec's and his jetting     send the  used cams i scored off ebay to webcams for their valkyrie spec or a bit better.......93 hp stock     + 13 for viking headers    + 5 on the airbox mod    +5 or so for the cam thats 23 hp up    to 116     now a 20-30 NOS shot when I run into a blower bike and I am good right???
Farther
Quimper Peninsula, WA
« Reply #21 on: January 21, 2013, 04:33:05 PM »
Do a dyno run after eash modification.  Your hp gains aren't necessarily a sum of each part gain.  In other words, the whole is less than the sum of the parts.
~Farther
Oklahoma_Valk
Central OK
« Reply #22 on: January 23, 2013, 03:33:16 AM »
If this is a joke... I don't get it. Horsepower costs money. If going fast is what you want...trade your Valk for a rice eating speed demon. There's lots of guys w speed demons looking for a nice cruiser in trade. If you want to tour the country side rather quickly, on the most badass machine known to man...keep your Valkyrie. And don't chop it up with goofy mods.
There's my .02
Let those who ride decide.
Len
« Reply #23 on: January 23, 2013, 04:00:10 AM »
Do what has been said and leave alone or be prepared to spend lots of time and money, more of the latter.  When I want to push the envelope I ride my ZX-12; it is not a trailer queen as it gets ridden to the mountains and other places...just make your machine comfortable for you.
As it's been said, the Valkyrie remains one of the smoothest bikes with power & torque for eating up long strips of road. Get the K&N filter to work with your current exhaust, have it dyna tuned and enjoy many miles and years of pleasure with your Valkyrie.
Just my two cents.
JC
The Beast
Franklin, TN
« Reply #24 on: January 23, 2013, 05:56:28 AM »
Put a K&N in it and leave the rest alone.
« Reply #25 on: January 23, 2013, 06:01:51 AM »
Stock airbox, oem filter
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #26 on: January 23, 2013, 11:19:15 AM »
THERE IS ONE THING HERE FOR SURE .... HE WILL MODIFY IT, AND HE WILL END UP SORRY THAT HE DID, AND WILL BE ASKING HOW TO STRAIGHTEN IT OUT.  IF YOU WANT TO GO FAST BUY A "BUSA".  IF YOU WANT A COMFORTABLE CRUISER THAT IS RELIABLE, THEN LEAVE THE AIRBOX ALONE.  AS SOON AS YOU CUT IT, THE BIKE WON'T RUN RIGHT.  YOU CAN DO ALOT OF THINGS TO MAKE IT SWEETER RUNNING, BUT IF YOU JUST WANT FAST, THEN THIS BIKE WILL NOT RUN WITH THE "BUSA" TYPE.
Blackduck
West Australia
« Reply #27 on: January 23, 2013, 01:24:46 PM »
Yep, runs sweet.
With the dyno print outs even mine are not truly representative. The time between runs even on the same Dyno are only an indication, in this case move dteh peak HP up the rev range.
Waste of time even trying to compare different Dynos.
The only true way is back to back runs on the same Dyno and then I would only compare against each other and not on "max " output.
Example is on the Dyno I used they had a free day when i got the 87 HP, a Blackbird at the same time pulled 130. Now Blackbirds make more than that. Just depends on the Dyno.
I only use it as a reference tool, I know how mine runs and it runs well.
I agree with leaving things alone unless you want to spend a lot of time and effort plus money.
Mine runs good but I doubt even setting another bike up the same will run good with out a lot of playing, very individual beasts at times.
I have had it like this for years and no problems
Anyone consdering doing the same has been warned, it is not easy and you better like yanking the carb bank off regular while setting it up
Momz
ABATE, AMA, & MRF rep.
« Reply #28 on: January 23, 2013, 02:18:52 PM »
-RP
I too have used a spacer to raise the tank for better airflow to the airbox. But it does not improve flow if you have a windshield/fairing, or other obstructions. JMHO
ALWAYS QUESTION AUTHORITY!
rocketray
« Reply #29 on: January 23, 2013, 04:59:10 PM »
I appreciate all the inputs...I learn something from all of them .... Please...I do not want to offend or irritate anyone..I love the bike and thought the car hop up stuff from my youth would still be relevant...so far lesson #1    the stock exhaust is restrictive  the archives say and that I understand to be why bigger cams wont work    #2   the viking exhaust is supposed to eliminate the restriction issue I understand so it could be a bigger cam will work  by my figuring #3   Bob/attic rat said the airbox is restrictive and he mods it with additional head milling and porting and piston cutting  and carb rebuilds/jetting with painstakingly arrived results from  a "mere"3 years(LORDY) of exhaustive dyno testing for a very reliable widely endorsed  108 H.P.package. Black Duck shows some good results also with his mod and rejet   #4   a nitrous spray into the box seems to have been used to good effect by several people        I have had several sport bikes and am too old to deal with a praying mantis  riding position    further in my experience  police despise sportbikes and generally ignore old fat guys on cruisers   so maybe putting the cams in and doing Blackducks carb set up and airbox mod would be interesting  for a grand or so..  currently there are 8 airboxes on ebay for about $25 ..nothing lost?
« Reply #30 on: January 24, 2013, 05:12:34 AM »
Might as well get one of the airboxes now.  Hoser  Wink
« Reply #31 on: January 24, 2013, 05:59:28 AM »
got a spare airbox from pinwall for $20 last yr and it had a brand new air filter in it. A Blessing!!!
rocketray
« Reply #32 on: January 26, 2013, 03:10:48 PM »
well the comments keep coming in....boy am I confused      my dad had a Lotus XI with a  roughly 1500 cc motor    alpha romeo      it had some downdraft webbers    and of course headers     and  it snarled and rasped      I wanna cut  a hole in the airbox and slide in some mild/mod cams in a  package that  some regard as anemic.......and boy howdy   talk about landing on the moon...       that "73" Olds  Cutlass Salon  455 came alive with a flip of the air cleaner  lid as did  that Suzuki   and that "68" Ram Air Firebird  my brother passed on to me   I put a bored out 455 with the complete  Edelbrock package  with aluminum heads and all and Nitrous for some 750hp   my Z 06 corvette via 2003  swallowed some air and exhaust stuff.......is this some italian untouchable thing like the  DeTamaso Mangusta  I drove in Higth School that kicked ass once a Boss 302 was installed????
tank_post142
south florida
« Reply #33 on: January 26, 2013, 03:59:39 PM »
so ok, this engine, intake, exhaust,electronics. is pretty much maxed out from the factory. you can change the exhaust, open up the intake system, mill the heads, modify the carbs, add a set of hopped up cams and gain, what? 8-12 hp? and spend, what? $2200-3200 ? just get up off the cash a supercharge it. it will be a reliable, proven 150hp for about $4000 or so.
I got a rock Sad
VRCCDS0246
« Reply #34 on: January 26, 2013, 04:05:56 PM »
Got a picture of that ZO6 with the Valkyrie parked beside it ?
« Last Edit: January 26, 2013, 05:53:33 PM by Smokinjoe-VRCCDS#0005 » Logged
tank_post142
south florida
« Reply #35 on: January 26, 2013, 04:08:09 PM »
you mean RocketRay ?
I got a rock Sad
VRCCDS0246
rocketray
« Reply #36 on: January 27, 2013, 02:48:21 PM »
per the archives      Dag posted a dyno with 108 hp     a '97 with the stronger cams and the Viking headers    I have those headers  and their needles on mine  now  and it is downright annoying to the Hardly crowd pulling  in revving to the  8k RPM via the dyna 3000 at Strokers here in Dallas    I just want to send off the cams I scored on Ebay for $60 for an additional lope at $612  at WEB cams...cut a wee 2" hole in the airbox via Black Duck and rejet with his specs.....so I am out a grand??? for another 10 hp to 116      and a cheapo NO2 spray into the airbox for 20-30 h p for $500??     or O.K.     who does the Blower for $4k that is  reliable???   thanx for the feedback     and yes I will post a picture of the ZO6 when I figure out how to post a picture      I can send a cell phone picture and some computer  guy can post it    the vette is Torch Red      and the bike is Blue.......with a White  Racing stripe....
« Reply #37 on: January 27, 2013, 03:25:40 PM »
Just to add to the confusion, I ran mine one time on a dyno, bone stock on an extremely hot/humid day. Temps approaching the upper 90's with humidity to match. Results....better than Blackducks charts show....remember, mine was BONE STOCK. Stock jetting, both slows and mains, stock pipes at the time, stock intake filter....everything OEM. I've made a few changes since then but overall I'm happy with what I have without spending myself into the poorhouse.
Just sayin'
john
tyler texas
« Reply #38 on: January 27, 2013, 05:49:59 PM »
airbox mods                               Shocked      ???      Undecided          coolsmiley         2funny
vrcc # 19002
Disco
Republic of Texas
« Reply #39 on: January 31, 2013, 03:26:01 AM »
Hey Ray,
If you make any mods, please let us know what you did and how it all turns out.
Disco
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
