February 06, 2026, 07:54:27 AM *
Author Topic: Gold wing shocks  (Read 1224 times)
Chiefy
Sarasota, Florida
« on: January 21, 2013, 06:21:26 PM »
I have a line on a set of GL 1500 shocks.  Haven't seen them yet.  But there is no compressor.  If the airshock doesn't have the original hose and/or fitting on the shock, is that a cheap fix?  I was looking at those parts on a site with an OEM fische.  The price for the hose wasn't cheap.  Would I be able to get some fittings and hose cheap at Lowes?  Or is this all proprietary?
PhredValk
Edmonton, Alberta, Canada
« Reply #1 on: January 21, 2013, 11:13:48 PM »
My understanding is that you should be able to jury rig them with pressure hose and an air valve fitting. You can add a compressor if you want, but it's a home build kind of thing. Others will chime in I'm sure. MarkT has some advice, as does Fordmano. Search is your best friend.
Fred.
VRCCDS0237
Westsider
Fort Worth TX.
« Reply #2 on: January 22, 2013, 10:37:52 AM »
The r/h is the air side, fitted with a schrader valve,, or small plastic air line going to a schrader valve ,, like car air shocks, under seat or whatever, you/we will only need a small hand air pump to adjust the ride, if needed, I have some on the way also.They are a little longer than stock shocks , 13-1/4" 13-3/8" center to center, compared to stock 13". I have about $65.00 into both shocks and they look like new, used very little, from trike conversions. cooldude
{ fitted=meaning I/ we will have to "fit" the schrader valve }    Smiley Smiley   I'm 6'1''  270#. So I think just enough air psi. in the air side to equalize with the spring side is all that will be needed. Its probably a little over kill for me, might be more of a trailer pulling or two up riders type mod.
« Last Edit: January 22, 2013, 02:49:59 PM by Westsider » Logged
Chiefy
Sarasota, Florida
« Reply #3 on: January 22, 2013, 10:44:12 AM »
The r/h is the air side, fitted with a schrader valve, or line going to a schrader , like car air shocks, under seat or whatever, you'll only need a small hand air pump to adjust your ride, if needed, I have some on the way also.They are a little longer than stock shocks , 13-1/4" 13-3/8" center to center, compared to stock 13". I have about $65.00 into both shocks and they look like new, used very little, from trike conversions. cooldude
My transaction is going agonizingly slow.  LOL I think the guy is only online once or twice a week to check his email.  We haven't cemented the deal yet.
PhredValk
« Reply #4 on: January 22, 2013, 10:30:14 PM »
Chiefly, what kind of pipes are on that bike?
Fred.
VRCCDS0237
Chiefy
Sarasota, Florida
« Reply #5 on: January 23, 2013, 04:26:54 AM »
Fred.
Two Brothers racing 6 into 2.  They were on the bike when I got it.  Nice deep throat sound, like a Porsche with glasspacks.
