April 30, 2026, 04:02:29 AM *
Author Topic: Bad pinion cup and shaft...  (Read 2661 times)
hotglue #43
« on: January 22, 2013, 06:46:21 PM »
 Well.. went in to do regular maint. on the rear end and found the pinion and shaft in VERY bad shape....
  Full of dusty rust and the splines are almost not there.... one good twist of the throttle.. and it would be slip city...
  I have checked them on a regular basis, 10,000 miles.... and they were always in good shape.   What I found this time when I pulled the pumpkin from the swingarm was:  oil in the swingarm housing, and the pinion cup was bone dry....
  After tearing everything apart, it seems the oil seal under the pinion lock ring..( the one under the pinion cup)  was leaking and not allowing the oil in the hub to reach the pinion cup intake holes.  The hole to lube the pinion cup were clear, it just seems the oil could not reach them .  At least that is the best sense I can make of it.  The oil seal on the drive shaft appeared worn and dry...
  I will be replacing the pinion cup, and the oil seal and o-ring under it... and the drive shaft and oil seal on it.
  I really think the oil seal under the pinion cup is what caused the problem.  I think it lowered the level of lube in the hub enough to not let it oil the pinion cup.  It leaked into the swingarm housing... but did not leak out and onto the ground.... I would have found that...
Ordered parts tonight, will put it back together when they come in.
 blue=3 times
 green=at least 4 times
Mofla
San Antonio TX
« Reply #1 on: January 22, 2013, 07:05:05 PM »
that checkin every 10k is a concern. guess i better not b assuming everythings gettin oiled !
mo
hotglue #43
« Reply #2 on: January 22, 2013, 07:13:08 PM »
I kinda wish the oil had leaked out onto the ground at the pumpkin to swingarm connection.... I would have found that....  The best I can figure is the oil leaking into the swingarm lowered the level enough to not feed the pinion.....Like I said... my best guess after tearing it apart....
  but yeah... 10,000 miles ago it looked new... now it's toast.
  Heah.... they are old bikes.. and getting older... I think rubber parts will be their downfall.....  I have a set of new carb o-rings and gaskets I will be putting in the bike before next summers' trips.
 blue=3 times
Sparky51
Houston, TX
Houston, TX
« Reply #3 on: January 23, 2013, 06:38:50 AM »
Is there not a lot of discussion on the board about the same issue you are having HG?  Need open weep holes for the oil to splash up into the teeth, but I have heard others say to go ahead and lube the pinion cup just like you do the rear end splines.   Anyone want to chime in?
Joe Hummer
Arnold, MO
« Reply #4 on: January 23, 2013, 07:01:07 AM »
I had mine do the same thing...one tire change...it was good to go...next time...it was rusted bits....When I took mine apart, I noticed the oil seal on the shaft was not in the cup (even though I know I put it in there the last time...).  I think this had something to do with my problem...don't know about HG's...
Joe
1999 Valkyrie Interstate
hotglue #43
« Reply #5 on: January 23, 2013, 02:26:56 PM »
My seal on the shaft was in the cup.....  the oil seal under the cup and threaded keeper for the pinion was leaking, and there was oil in the swingarm shaft housing.... It is a puzzlement... but the pinion cup and driveshaft are toast.... they were dusty dry......
  I think just enough oil was lost to the housing that the level was not feeding the pinion cup...... the feed holes in the cup were open.... and I did put some grease on the shaft and in the cup last time I put it together.
« Last Edit: January 23, 2013, 02:28:29 PM by hotglue #43 » Logged
 blue=3 times
Disco
Republic of Texas
« Reply #6 on: January 26, 2013, 07:58:50 AM »
Now you have me a little anxious, Mark.  I'm past my normal (full) service interval and even a little more than a normal interval past my last peek that was necessitated by a rear tire change.
Guess we get to test my "pookie the hell out of it" theory!
« Last Edit: January 26, 2013, 01:36:11 PM by Disco » Logged
22 CRF450RL, 19 BMW R1250RT
78 CB550K, 07 Helix
71 MT50 Trailhopper
Willie
I am better than I deserve to be
Lake Jackson, TX
« Reply #7 on: January 26, 2013, 01:19:19 PM »
HG, have you put it back together yet??  If not, when do you think you might, I would like to watch and learn.
thanks, Willie
2002 Black Standard
1974 Suzuki 100TC
VRCC #32624
hotglue #43
« Reply #8 on: January 27, 2013, 09:08:04 PM »
Willie
  They say the parts should be here Tuesday...  I will be working some this week.. so I may put it back together this weekend if the parts arrive..  Come on down!
I'll keep ya posted.
 blue=3 times
hotglue #43
« Reply #9 on: January 27, 2013, 09:36:29 PM »
Well.... there's nothing wrong with a little... or a LOT of pookie!!!!!!!! coolsmiley Grin
 blue=3 times
Willie
Lake Jackson, TX
« Reply #10 on: January 28, 2013, 05:57:04 PM »
Thanks, HG - do keep me posted.
Willie
2002 Black Standard
1974 Suzuki 100TC
VRCC #32624
franco6
Houston, TX
« Reply #11 on: January 29, 2013, 10:12:23 AM »
last time I cheked mine it was fine but it had grease on it. When I putit back together I added more pumpkin lube. Its due for a look-see but that darn tire will not wear off!  Wink
Enjoy the ride!
hotglue #43
« Reply #12 on: January 29, 2013, 09:22:00 PM »
Willie
Looks like I may try to do it Sunday....  we have been packing and moving the Mother-in-law this week, and will have a garage sell on Fri and Sat.....
 blue=3 times
Joevalk
Santa Fe, Texas
« Reply #13 on: January 29, 2013, 09:28:52 PM »
anything good in the garage sale?
VRCC#32720
1999 Grn/Silver Interstate
hotglue #43
« Reply #14 on: January 30, 2013, 05:55:00 AM »
There is always something good.... cooldude coolsmiley
 blue=3 times
Wanderer
The Great Republic of Texas - Dallas
« Reply #15 on: January 30, 2013, 09:19:06 AM »
How 'bout drilling a weep hole in the swing arm housing, or similar mod as a "tell all", Mark? Oughta be some way for all to benefit from your experience, maybe??? ~Jeff
More Valk Pics...
had a couple of Valks once upon a time
2004 DRZ400S
2005 GS1200
1978 CB550K
1977 CB550F
hotglue #43
« Reply #16 on: January 31, 2013, 03:11:33 AM »
I'd be sceered water could get in there.  If it did, the water would be at the outside of the pinion cup, at the oil seal to the rearend.
  The new parts are in.... and the old pinion cup had some pretty good wear where the oil seal ran on the cup.  This is the 1st time I have heard of this failure.....  maybe something we will have to watch for.
 blue=3 times
« Reply #17 on: January 31, 2013, 06:55:26 AM »
Isn't this o-ring much like the one on the drive hub where there is not much movement between the 2 sealing surfaces?  Wonder how that thing had any wear on it?  Was the pinon cup nut loose when you removed it?
So many questions......  Smiley
Hay  Cool
Disco
Republic of Texas
« Reply #18 on: January 31, 2013, 07:40:50 PM »
How 'bout some pictures.   Wink
78 CB550K, 07 Helix
71 MT50 Trailhopper
hotglue #43
« Reply #19 on: February 02, 2013, 04:09:21 PM »
Part number 31 is the oil seal that runs on the pinion cup and leaked the oil to the shaft housing/swingarm.   The drawing is not exactly right... the o-ring #35, goes under the pinion lock nut #10......
Got FB's mom moved Thursday...We had the garage sale yesterday and  today..got rid of a bunch of her old stuff..!!!.. so I plan to put the rearend back together tomorrow afternoon.... yeah... I know it's Superbowl Sunday.....  but I need to go see my mom in the morning..... and I have been doing some consulting and will need to work next week.... so tomorrow after noon is it.
« Last Edit: February 02, 2013, 04:11:46 PM by hotglue #43 » Logged
 blue=3 times
Willie
Lake Jackson, TX
« Reply #20 on: February 02, 2013, 05:14:30 PM »
Hey, HG, while I need to watch all i can, I am going to be getting ready to watch the super bowl.  Since I put in the request for the food, it would not be well received for me to leave all the cooking to TBird, so I will be playing sous chef instead of watch Chef Mark work on the Valk.  Thanks for keeping me in the loop...
I know, I have wisdom beyond my 50 something years....
Willie
2002 Black Standard
1974 Suzuki 100TC
VRCC #32624
hotglue #43
« Reply #21 on: February 02, 2013, 05:45:38 PM »
Willie.... LOL!!!!!
  Well... plans have changed.... I have been informed that tomorrow I will be re-arranging furniture, and hanging pictures at the Mother-in-law's new place....  I will try to set a new time for the re-build.... with some warning...Enjoy the game!!!!!!!
 blue=3 times
Willie
Lake Jackson, TX
« Reply #22 on: February 02, 2013, 05:53:00 PM »
Thanks for accommodating....
Do keep me in the loop....
Willie
2002 Black Standard
1974 Suzuki 100TC
VRCC #32624
hotglue #43
« Reply #23 on: February 05, 2013, 05:50:14 AM »
OK.... my schedule is wacko.....  Will be putting the bike back together this afternoon.....2/5/13
 blue=3 times
hotglue #43
« Reply #24 on: February 05, 2013, 05:25:27 PM »
Welp... didn't work the bike  on the stuff today.... me and the BIL were doing Duck Dynasty stuff all day.... ridin the 4 wheeler... working in the pasture....  working around the pond....  caught a mess of fish.... Hey... we didn't blow anything up.......
Hey ... I've been doing this stuff all my life.....  Happy Happy Happy
 blue=3 times
« Reply #25 on: February 05, 2013, 07:18:51 PM »
Hay!  that sounds like fun stuff right there Jack!
Only thing you needed was to shoot some stuff...
Hay  Cool
hotglue #43
« Reply #26 on: February 06, 2013, 08:25:07 AM »
Have a meeting west of Houston this afternoon.  Will come home and work on putting it back together.... good rainy day project!
 blue=3 times
Disco
Republic of Texas
« Reply #27 on: February 17, 2013, 05:24:57 AM »
My "pookie the hell out of it" theory worked!
78 CB550K, 07 Helix
71 MT50 Trailhopper
Valkpilot
What does the data say?
Corinth, Texas
« Reply #28 on: February 17, 2013, 06:20:08 AM »
You just like saying "pookie."
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
