February 06, 2026, 07:54:32 AM
Starter relay maintanence
Topic: Starter relay maintanence (Read 1095 times)
hoosier jaybird
NE IN.
January 27, 2013, 04:31:23 PM »
After reading threads on starter relay issues I checked the terminals on the relay and sure enough there was corrosion on my 99 I/S. Will electrical contact cleaner work to get rid of the corrosion ,then use dielectric grease on the terminals to prevent further corrosion? Thanks.
Re: Starter relay maintanence
January 27, 2013, 04:55:20 PM »
At the shop, when we encounter a corroded terminal, it is washed/brushed down with Coca Cola.
Then it is washed and dried with plain water. Then comes the red spray in a rattle can or a gob of wheel bearing grease.
My vehicles have the red spray stuff in da rattle can.
john
tyler texas
January 27, 2013, 05:47:34 PM »
fine wire brush ...emory cloth ... dielectric grease
both battery cables and every thing under right cover
unplug anything ... light bulbs ... use the dielectric grease
vrcc # 19002
