November 25, 2025, 06:44:32 PM *
Author Topic: Another petcock question  (Read 1404 times)
Stitch_in_La
Bentley Louisiana
« on: January 29, 2013, 09:58:58 PM »
Got bike disassembled to painter checking parts noticed that the long tube of the petcock appears to be split part way down.  Is it supposed to be that way?  Time for a Pingle??
Stitch
« Reply #1 on: January 30, 2013, 05:13:14 AM »
Did you unscrew the "secret screw" that you get to through the hole in the on,off,reserve switch?  If not it broke when you removed the tank.
I think its time for a Pingel as soon as you get a Valkyrie
« Last Edit: January 30, 2013, 05:17:18 AM by Chrisj CMA » Logged
9Ball
« Reply #2 on: January 30, 2013, 05:24:48 AM »
are you talking the actuator arm, or the brass petcock feed tubing that goes inside the tank, or the plastic screen (part #4 in the attached link) that covers the petcock feed tubing inside the tank?
This will help with the diagnosis...here's a link with the diagram of the petcock
http://www.directlineparts.com/product.asp?pid=44481&str=0&mdl=1539&mdy=1999
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
Stitch_in_La
Bentley Louisiana
« Reply #3 on: January 30, 2013, 07:55:05 PM »
Brass tubing inside tank,  Screen not there at all upon disassembly.  Ujjjjjj have a Valkyrie just in little pieces on the pool table in the game room, well there and the great big piece out in the workshop.  Even naked the fat lady is impressive.  Some friends of the daughters were over (Harley people) guy looked at it told his SO about the beast I had.
Stitch
Bone
« Reply #4 on: January 31, 2013, 02:13:58 AM »
Did you look in the tank ? First time I pulled the petcock the screen stayed in the tank they have been in there many years. I grabbed it with some pliers and twisted it loose then pulled it out. The screen had to be replaced try and find a new one before you start.
« Reply #5 on: January 31, 2013, 05:17:45 AM »
Time for a new petcock?  Roll Eyes Undecided ???
My rides:
Stitch_in_La
Bentley Louisiana
« Reply #6 on: January 31, 2013, 07:54:53 AM »
The openings in the tank still taped up, noticed the screen in the picture, didn't hear anything rattlin around in the tank but will check.  Salty1 thats what the question is.
Stitch
Bone
« Reply #7 on: January 31, 2013, 08:29:56 AM »
Doubt it will rattle around the end sticks to the circumference of the hole. Some guys posted they re-used the screen I twisted the base during removal.
« Reply #8 on: January 31, 2013, 08:57:20 AM »
Stitch
The answer is ... Yes
« Reply #9 on: January 31, 2013, 11:45:23 AM »
+1 I totally agree with Chris! Now you get to decide OEM or Pingel?
My rides:
Stitch_in_La
Bentley Louisiana
« Reply #10 on: January 31, 2013, 05:14:53 PM »
I'm leaning pingel just to avoid the hydrolock problem entirely.  Question that I don't remember seeing is does the OEM handle fit the pingle ?  I know its here somewhere what is the pingle number?
Stitch
« Reply #11 on: January 31, 2013, 07:29:43 PM »
Stitch
No, the OEM switch (the knob for on,off,res) goes away when you install the Pingel
valkyriemc
NE Florida
« Reply #12 on: February 03, 2013, 03:51:35 PM »
I left mine in place for looks, secured it with a small Philips head screw.
Veteran USN '70-'76
« Reply #13 on: February 04, 2013, 05:57:28 AM »
Stitch
I prefer the OEM petcock in combination with a Dan Marc valve. FWIW.
My rides:
