November 25, 2025, 06:35:05 PM
vacuum lines??
Topic: vacuum lines?? (Read 1164 times)
flcjr
Manhattan,Montana
vacuum lines??
January 31, 2013, 02:41:15 PM »
So was planing some maintience while the snow is flying. Gonna take the tank off for new filter and rebuild petcock. visual inspection some vacuum lines appear to be cracking. What size hose is it? Is it all the same size? Just want to have it on hand while I am there thought I would just replace it all.
Denny47
#34898
Grove, Ok.
Re: vacuum lines??
January 31, 2013, 03:58:55 PM »
1/8 will work in an emergency but I believe 5/32 would be the right size.
1997 Green/Cream Tourer w/ Cobra 6/6 exhaust, 2012 Pearl White Goldwing
USAF 66-70, F-105 AWCS
Thunderbolt
Worthington Springs FL.
Re: vacuum lines??
January 31, 2013, 04:00:49 PM »
I use 5/32, fits a little tighter than the OEM, but you can chunk those pesky little clamps.
Farther
Quimper Peninsula, WA
Re: vacuum lines??
January 31, 2013, 05:27:37 PM »
You probably can't do better quality than here:
http://redeye.ecrater.com/c/1086116/vacuum-line-cap-kits
~Farther
flcjr
Manhattan,Montana
Re: vacuum lines??
January 31, 2013, 08:25:24 PM »
thanx for the info
Attic Rat
VRCC # 1962
Tulsa, OK
Re: vacuum lines??
February 01, 2013, 07:38:32 AM »
the proper size is 3.5mm here is a link to where you can buy the Silicone Vacuum 3.5 hose.
http://www.boostcontroller.com/index.php?page=1&category=8&category=8&item=751&min=1&minqty=10&prid=751
Re: vacuum lines??
Reply #6 on:
February 01, 2013, 08:08:38 AM »
Quote from: Attic Rat on February 01, 2013, 07:38:32 AM
That's the stuff I bought right there... good stuff
Hay 8
Re: vacuum lines??
Reply #7 on:
February 01, 2013, 08:28:38 AM »
Quote from: HayHauler on February 01, 2013, 08:08:38 AM
Hay 8
That is what is on MGM, and has been there for about 5 or 6 years.
Very good stuff.
Attic Rat
VRCC # 1962
Tulsa, OK
Re: vacuum lines??
Reply #8 on:
February 02, 2013, 07:16:19 AM »
I use to build cruise contols and that is the only vacuum house that I found that would withstand the heat and not get hard and crack open so when I do the performance work on my customers bike I always use that vacuum hose
=> InZane XXV
