November 25, 2025, 06:35:03 PM *
Author Topic: Fork oil  (Read 946 times)
silver337
San Diego, Ca
« on: February 01, 2013, 12:44:13 PM »
Is there a way to change the fork oil with out disassemling the whole fork. The fork is off the bike can't I just remove the bolt that goes up from the bottom and drain the oil?
« Reply #1 on: February 01, 2013, 01:16:48 PM »
A bolt goes up from the bottom ? Hmm. I just set 'em upside down and let them drain.
« Reply #2 on: February 01, 2013, 01:25:17 PM »
Suck it out with a mityvac and put the same amount out of new fluid in that you got out.  Hoser  Smiley
N8171S
Marlboro, Mass
« Reply #3 on: February 01, 2013, 02:14:06 PM »
There is no drain on the bottom of valkyrie forks.
« Reply #4 on: February 01, 2013, 07:35:00 PM »
The bolt on the bottom (right fork only) is the lower mount for the dampner inside the tube. Oil is drained by removing the top and pouring it out. Replace the fork back in the triple tree and tighten the "lower" tree pinch bolts. Use a 15/16" box wrench and loosen the fork top. Then take the fork back out and dump the oil.
silver337
San Diego, Ca
« Reply #5 on: February 02, 2013, 05:54:49 AM »
I keep forgetting the forks are inverted. I got it, just turn it upside down stupid. LOL
