Scooby
« on: February 05, 2013, 07:26:15 AM » |
I need a sealing washer for the bottom housing after I pull the plug to drain the coolant, and a sealing washer for the oil drain and the final drive drain along with the o ring for the final drive fill, where is the best place to order these from? Also wondering if there is a option for coolant other than the quarts from Honda? I have 2 quarts of the Honda on hand, but it looks like I need 3 more, but I would entertain something else that is cheaper if it is available?
Thanks- Scooby
« Reply #1 on: February 05, 2013, 11:57:04 AM » |
I've changed my engine and final drive oil many times and never changed the crush washers. I've only changed coolant once (to put in Evans NPG+ coolant) and didn't change that crush washer either. None of these have leaked.
olddog1946
« Reply #2 on: February 05, 2013, 12:06:21 PM » |
Take your washers to the local auto parts store and match them up with what's in the store. I used the supertech anti-freeze, as long as you find silicate free stuff you will be fine.
VRCC # 32473 US AIR FORCE E7, Retired 1965-1988 01 Valk Std. 02 BMW k1200LTE 65 Chevelle coupe, 1986 Mazda RX-7 with 350/5spd, 1983 Mazda RX-7 with FOMOCO 302/AOD project, 95 Mustang GT Convertible 5.0, 5 spd Moses Lake, Wa. 509-760-6382 if you need help
« Reply #3 on: February 05, 2013, 12:29:33 PM » |
+1 and that's for the evans also.
« Reply #4 on: February 05, 2013, 03:30:13 PM » |
Plus 1, I use prestone premix, don't add any water. I change it every 50,000 miles. Hoser
Chiefy
« Reply #5 on: February 05, 2013, 05:41:10 PM » |
The sealing/crush washers don't cost much even at a Honda dealer. Buck and half or so. Much cheaper on line, but with shipping? My dealer has all those in stock all the time.
DenverDave
« Reply #6 on: February 06, 2013, 06:35:18 PM » |
Plus 1, I use prestone premix, don't add any water. I change it every 50,000 miles. Hoser  Last year, when I was looking at anti-freeze, I was thinking about using the premix 50/50 stuff, after after talking to a long time motorcycle mechanic, I used the full strength anti-freeze and diluted it myself. If you test the 50/50 right out of the bottle you don't get the protection you would expect. Seems like 50/50 is a little optimistic. Get the full strength stuff, you get two gallons of real 50/50 for less than two gallons of the 50/50 premix. Just my 2 cents. Dave
1999 interstate green/silver Denver, Colorado VRCC#32819 VRCCDS#0238
« Reply #7 on: February 07, 2013, 02:10:39 PM » |
Checking the ph of the coolant that's presently in the radiator and maintaining it at the correct level (ph) is probably better preventive care than screwing with new stuff all the time.
Less expensive too!
Tropic traveler
Silver Springs, Florida
« Reply #8 on: February 07, 2013, 04:15:17 PM » |
The Honda ready to use coolant is $7.50 a qrt at my local Honda dealer. I think it takes 4 qrts. Is it really that expensive to you? Seems a reasonable cost for something that you KNOW is the right stuff & lasts a long time. IMHO.
'13 F6B black-the real new Valkyrie Tourer '13 F6B red for Kim '97 Valkyrie Tourer r&w, OLDFRT's ride now! '98 Valkyrie Tourer burgundy & cream traded for Kim's F6B '05 SS 750 traded for Kim's F6B '99 Valkyrie black & silver Tourer, traded in on my F6B '05 Triumph R3 gone but not forgotten!
shortleg
« Reply #9 on: February 08, 2013, 04:35:44 AM » |
Go to the Honda car dealer and buy a gallon from them. It is the same stuff and cheaper. Shortleg[Dave]
1500Rider
« Reply #11 on: February 08, 2013, 11:58:14 AM » |
Anybody know of a Evans Coolant dealer in Canada? Contacted a couple listed on Evan's web site but some don't carry it any longer and others never got back to me.
1990 Honda VFR750F 1997 Honda Valkyrie GL1500 Tourer 1998 Honda Gold Wing GL1500 SE
