April 30, 2026, 04:02:33 AM
Texas Chapter
(Moderator:
Daniel Meyer
Clutch fluid
Topic: Clutch fluid (Read 1458 times)
Mofla
San Antonio TX
Clutch fluid
February 05, 2013, 08:11:18 AM »
My clutch seems to be maybe not engaging as well as it should. Hard shift. My fluid seems low for starters. Do i dare top off with DOT 3. Calls for Dot 4. Thought I heard 3 & 4 are compatible but not 5 ? Thnks,,,,
Mo
Daniel Meyer
Moderator
The State of confusion.
Re: Clutch fluid
February 05, 2013, 08:22:27 AM »
DOT 3 & 4 are compatible...DOT 4 has a higher boiling point, which is why most motorcycles call for it in the brakes...if you brake HARD AND LOTS (to the point of nice glowing rotors) you supposedly could boil DOT 3. Completely irrelevant in the clutch, but if ya have DOT 4 on hand may as well use it.
Also check the two bushings in the lever for wear as this can cause significant clutch action issues.
CUAgain,
Daniel Meyer
RainMaker
Arlington, TX
Re: Clutch fluid
February 05, 2013, 08:32:26 AM »
If it looks like the color of molasses, it would be a good idea to change it as well. Should be almost clear.
2005 BMW R1200 GS
2000 Valkyrie Interstate
1981 GL1100I GoldWing
1972 CB500K1
Mofla
San Antonio TX
Re: Clutch fluid
February 05, 2013, 08:51:51 AM »
Awesome info guys !!! Speedy as well !!! Thnks !
Mo
Daniel Meyer
Moderator
Re: Clutch fluid
February 05, 2013, 09:32:43 AM »
Quote from: RainMaker on February 05, 2013, 08:32:26 AM
Good point...A changing/bleeding is pretty much the norm if you have to open up one of those master cylinders.
CUAgain,
Daniel Meyer
Mofla
San Antonio TX
Re: Clutch fluid
February 05, 2013, 04:17:47 PM »
Was real low, and molasses colored. I just topped it off. Didnt want to maybe wind up bleeding it.
Dont have the resources !!
Mo
franco6
Houston, TX
Re: Clutch fluid
Reply #6 on:
February 05, 2013, 05:09:40 PM »
also check that the master cylinder push rod is not protrubing or making a hole in the lever base. it has hapenned to me .was thinking clutch actuation rebuild. lol
Enjoy the ride!
Mofla
San Antonio TX
Re: Clutch fluid
Reply #7 on:
February 05, 2013, 05:54:22 PM »
Quote from: franco6 on February 05, 2013, 05:09:40 PM
thnks much everyone !
Mo
Mofla
San Antonio TX
Re: Clutch fluid
Reply #8 on:
February 13, 2013, 05:02:54 PM »
After the top off, and shimming the lever bushing ( till I find a new one ) seems to be right on !
Cheers !!
Mo
