February 06, 2026, 11:34:28 AM
98 Tourer Aux Power
Topic: 98 Tourer Aux Power (Read 1046 times)
Mike O
98 Tourer Aux Power
February 07, 2013, 04:09:24 PM »
I am wiring up my electronics and looking for the aux power plug. I see in the wiring diagram the 98 CT has a 5 amp aux power outlet. I found what appears to be a switched 12 volt plug near the front of the tank but it has really thin stranded wire like maybe 20 or 24 ga. I don't know if someone added this or if that is the 5 Amp drop shown in the schematic. I am thinking I should run my own line from the fuse to the front 14 or 16 ga and maybe bump up the fuse to 10 amp then. Any suggestions? I will be running a Radio (Shark), GPS (TomTom) and CB (J&M)
Re: 98 Tourer Aux Power
February 07, 2013, 05:52:22 PM »
The aux plugs are under the right side cover in a rubber cover. If you're running all three devices, I'd use the aux circuit to trigger a relay to pull in power to an added fuse panel. Then separately fuse each device.
ptgb
Youngstown, OH
February 07, 2013, 05:54:21 PM »
Here's a picture of it...
They are bullet connectors.
This pic is from an Interstate so ignore "stereo aux" and the other big connectors, they are for the I/S stuff. The power aux is the same on Standard/Tourers. Under the black rubber cover.
Last Edit: February 07, 2013, 05:56:16 PM by ptgb
