February 06, 2026, 09:35:02 AM *
Author Topic: Cheap heated grips.  (Read 1571 times)
F6BANGER
Albuquerque NM
« on: February 10, 2013, 08:11:15 AM »
A couple days ago I mad up a set of heated grips. Very inexpensive. Temporary just to see how well they worked. They work really good. 28awg 27' per grip covered with bicycle inner tube and some coax connectors. I used a 12v 8a led dimmer. In all it cost me about $6. painted the dimmer black and added a red LED for fun. I have plenty wire left over if anyone needs some. $5 per 100'.
wd40
Winnemucca, NV, Reno NV
« Reply #1 on: February 10, 2013, 08:54:25 AM »
Got to be REAL careful that the wires don't shift and touch.  If they move and touch, the effective length of wire goes way down resulting in extreme heat generation.  Hot enough to burn your hand, and possibly melt parts or even start a fire?
I did the same thing years ago, used large heat shrink to cover the grips.  Developed a short, trust me that wire can get HOT!!
F6BANGER
Albuquerque NM
« Reply #2 on: February 10, 2013, 09:23:24 AM »
This wire is insulated. It is crossed over its self many times. Plus it is over my ISO grips which are metal.
« Reply #3 on: February 10, 2013, 09:41:39 AM »
That's pretty cool!
I like it!
YoungPUP
Valparaiso, In
« Reply #4 on: February 10, 2013, 04:56:57 PM »
Guy I work with did the same idea last winter.  If you use shrink tube, make SURE its not the marine type thats adhesive lined......Dumba$$  ruined a set of ISO grips.
99 STD (Under construction)
jmann
Mesa,Az.
« Reply #5 on: February 11, 2013, 06:37:53 AM »
F6Banger, did you wrap 27 ft of wire or 27 inches? 27 ft seems like a lot but just wanted to make sure. I think I will have to try this. Where did you get the dimmer?
F6BANGER
Albuquerque NM
« Reply #6 on: February 11, 2013, 08:52:51 AM »
jmann, I used 27 feet per grip. The 28awg is really thin. Got the dimmer off of ebay.
jmann
Mesa,Az.
« Reply #7 on: February 11, 2013, 09:10:52 AM »
Thanks. I will give this a try. Pretty inexpensive way to see if I like it. Lot less expensive than heated gloves.   cooldude
« Reply #8 on: February 11, 2013, 03:19:05 PM »
love innovation   cooldude
remember that heated grips do NOT help the part of your hand that is exposed to the air !
my beemer police bike has heated grips and my palms and inside of my hands are warm or hot depending on the setting
All of my fingers however can still get damn cold from the big knuckles to the fingertips
Under 40-45 degrees I use my heated gloves if the ride is more than a half hour
Now if someone made a heated cowl for my toes to stay warm that would be something great
F6BANGER
Albuquerque NM
« Reply #9 on: February 11, 2013, 08:33:03 PM »
As you can see in the pic I have some (trial) homemade wind deflectors. I got some bigger pieces of acrylic to make some new ones. You can kinda see them in the bottom pic.
Wow, someone needs to wash that bike!!! Embarrassed
« Reply #10 on: February 12, 2013, 06:17:02 AM »
Cheaper, easier.  Hoser  cooldude
http://www.amazon.com/HeatMax-Hand-Body-Warmer-Count/dp/B0007ZF4Q8/ref=pd_ybh_11
F6BANGER
Albuquerque NM
« Reply #11 on: February 12, 2013, 08:09:56 AM »
heats up in 15 to 30 minutes. Your hands will be frozen by then....http://vimeo.com/user12572660/heatedapparel
« Reply #12 on: February 12, 2013, 01:48:45 PM »
I activate the warmers 30 minutes before I leave the garage, just followed the directions on the package saying they need half hour to warm up.  That being said,  I will probly try the ones above, pretty clever!    Hoser  Wink
« Last Edit: February 12, 2013, 01:56:12 PM by Hoser » Logged
