February 06, 2026, 09:35:05 AM
Harbor freight tire changer.
Topic: Harbor freight tire changer. (Read 2179 times)
Chiefy
Sarasota, Florida
February 13, 2013, 09:15:44 AM »
Harbor freight sells two cheap tire changers. One they call a portable tire changer, good for rims starting at 8 inches:
http://www.harborfreight.com/portable-tire-changer-69686.html
And one they call a mini tire changer, good for rims up to 12 inches:
http://www.harborfreight.com/mini-tire-changer-34552.html
Wondering if anyone has first hand info on either? I'm thinking the "portable" that starts at 8 inches will be just a tad too large.
Valkpilot
What does the data say?
Corinth, Texas
Re: Harbor freight tire changer.
February 13, 2013, 09:21:46 AM »
Quote from: Chiefy on February 13, 2013, 09:15:44 AM
They are referring to rim diameter, not width, so the portable would be the one you need.
Unfortunately, last I knew, they no longer offered the motorcycle wheel adaptor.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Chiefy
Sarasota, Florida
February 13, 2013, 09:25:54 AM »
Quote from: Valkpilot on February 13, 2013, 09:21:46 AM
Thanks for the clarification. How does the adapter work? Is it something that can be cobbled together?
F6BANGER
Albuquerque NM
February 13, 2013, 04:23:38 PM »
I have the portable tire changer. I also have the motorcycle attachment for it. I beefed up a pallet and mount it to that when I need to change a tire. I use it for both autos and motorcycles.
Denny47
#34898
Grove, Ok.
February 14, 2013, 05:39:50 AM »
The Harbor Freight tire changer was discussed a couple of weeks ago. If you will search Harbor Freight tire, it will pull up the thread with most of the info you need.
1997 Green/Cream Tourer w/ Cobra 6/6 exhaust, 2012 Pearl White Goldwing
USAF 66-70, F-105 AWCS
Chiefy
Sarasota, Florida
February 14, 2013, 06:05:12 AM »
Quote from: Denny47 on February 14, 2013, 05:39:50 AM
Thanks! Looks like I'll probably get one after all now.
For the next guy wondering the same thing:
http://www.valkyrieforum.com/bbs/index.php/topic,51636.0.html
Reply #6 on:
February 14, 2013, 11:48:43 AM »
I've had the HF tire changer and the motorcycle adapter for years. Has saved me a LOT of money. Plus I can easily change tires myself pretty quickly. Like if I took off a tire because it doesn't have enough rubber left for a big trip. Then put it back on later to use it up on local riding. I don't balance them anymore, having gone to Ride-On instead. Dynamic balancing works much better, plus the benefit of preventing most puncture flats.
