November 25, 2025, 06:32:46 PM *
Author Topic: Cobra Swept Floorboards and Kickshifter  (Read 925 times)
Algonquin Highlands, Ontario Canada
« on: February 16, 2013, 07:11:29 AM »
I just purchased a Rattlebars kickshifter. When I mounted it, the rear peg hits my Cobra Swept floorboards when you would be pushing down on it to shift.
Has anyone experienced this and found a solution or do I have to purchase different floorboards?
OK, can anyone tell me what make of floorboards they are using with their kickshifter?
« Last Edit: February 16, 2013, 12:24:07 PM by Mike » Logged
« Reply #1 on: February 16, 2013, 08:02:13 PM »
I (and many) use Cobra traditional/classic boards with the kickshifter with no clearance problem at all.  I think you just have to adjust the shifter mount on the spline one tooth or so (I think down, so the rear is a tad higher).  I do not use a peg lowering kit with this setup, some do.
ptgb
Youngstown, OH
« Reply #2 on: February 16, 2013, 08:04:34 PM »
Cobra swepts on the wife's Valk trike with the Rattlebars kicker. I think I did move the shifter down two or three splines, can't remember for sure how many.
It clears with no problem. I would check your install.
Sorry, the only picture I have of it that shows the boards and shifter, but gives you an idea how far the rear peg is away from the board:
« Last Edit: February 16, 2013, 08:18:13 PM by ptgb » Logged
WDAN
Irving, TX
« Reply #3 on: February 16, 2013, 08:14:45 PM »
I have the Rattlebar kickshifter with Cobra swept boards and the peg lowering kit. Works great.
WDAN
Irving, TX
« Reply #4 on: February 17, 2013, 11:28:10 AM »
Thanks all, you were all spot on with moving the shifter a few notches. Forgot that it could be moved.
