November 25, 2025, 06:33:10 PM *
Author Topic: front brake issue  (Read 898 times)
rocketray
« on: February 17, 2013, 08:28:48 PM »
  My front brake is very stiff at the lever and takes all four fingers to get much braking. It has slowly been getting worse over the years. I had a local dealer put on steel brake lines last year with fresh fluid and all and it didnt help. My wife's VTX is a one finger deal.  What is up??  Thanx
« Reply #1 on: February 17, 2013, 09:58:33 PM »
My first guess is either the master cylinder or the calipers need rebuilding.  Or check the obvious; is there oil on the disks/pads?
Joevalk
Santa Fe, Texas
« Reply #2 on: February 17, 2013, 10:13:23 PM »
When I bought my interstate, it was the same way. I rebuilt the master cylinder and lubed the lever and all was great. Try lubing the lever first cooldude
VRCC#32720
1999 Grn/Silver Interstate
PhredValk
Edmonton, Alberta, Canada
« Reply #3 on: February 17, 2013, 10:36:09 PM »
Two fingers should be able to almost lift the rear tire off the road. Rebuild or clean out the calipers and re-bleed the lines. Just because the dealer did them doesn't mean there ain't air in the lines. New OEM pads, if the rotors are stock.
Fred.
VRCCDS0237
longrider
Vernon, B.C. Canada
« Reply #4 on: February 18, 2013, 07:34:28 AM »
As said before  lube the pivot on the lever.  should be done on both the front brake and clutch once a year.  I also lube the rear brake pivot as it will make a difference as well.
warren
« Reply #5 on: February 18, 2013, 09:15:00 AM »
While not on the front when my rear caliper f---- up it locked. Could not roll at all. Thank goodness i was in my garage. Are you getting ANY braking at all off the front?? I'm with the others on bleeding the system. With 2 fingers you can lock up the front of my I/S at ANY speed you desire. If you get as far as taking off your calipers and the exposed metal on the pistons looks grey AND fuzzy-rebuild time usually. Try bleeding first. And the swept areas of the rotors should be fairly shiny and DRY. And as a bit of info-when i did rebuild the rear caliper i needed high pressure air to remove the pistons from the caliper. They were THAT corroded. RIDE SAFE.
rocketray
« Reply #6 on: February 18, 2013, 04:15:09 PM »
Joevalk you are a genius!!...and I am an idiot!!.I can't believe 4 drops of oil fixed it.....and I put up with those horrible brakes  for so long....thanx to everybody!!
Joevalk
Santa Fe, Texas
« Reply #7 on: February 18, 2013, 05:56:08 PM »
If I was a genius, #1&3 cylinders would be firing after rebuilding my carbs uglystupid2 I'm glad your brakes are working better. I coat my pivots with antisieze, a lil dab il do ya cooldude
VRCC#32720
