February 06, 2026, 11:33:45 AM *
Author Topic: Boggy throttle  (Read 1463 times)
localyokel
Newport Beach CA
« on: February 17, 2013, 09:10:19 PM »
Any tips for a super boggy throttle response? I have a 98 with 6-1 cobras and stock carbs. The previous owner had the carbs rebuilt by Honda due to the same problem, with the OEM exhaust. I drove the bike just a little before changing pipes, and the problem was there but did not seem as bad. Throttle response is quite poor. Only 4k orig miles on this beast.
F6BANGER
Albuquerque NM
« Reply #1 on: February 17, 2013, 10:30:19 PM »
How long has it sat?
PhredValk
Edmonton, Alberta, Canada
« Reply #2 on: February 17, 2013, 10:33:08 PM »
A couple of tanks of fuel with Sea Foam could help, and maybe IS carb springs...
Fred.
VRCCDS0237
« Reply #3 on: February 18, 2013, 03:56:29 AM »
I too would look at the carburetor jets and air filter. I'm suspect of being told that the carburetors were cleaned, I always wonder how well they were cleaned. Run several heavy doses of Sea-foam thru it and try to keep the engine speed low [2000 rpm]. Is the poor throttle response all the time, or just at low engines ?
« Reply #4 on: February 18, 2013, 09:46:05 AM »
A 98 with ONLY 4 K has been doing a LOT of sitting. This alcohol gasoline we burn creates a lot of varnish when it just sits. Run a can of B-12 Chem Tool thru it. Most auto parts stores and wally wurld carry it. And when you put the treatment in with a FULL tank of FRESH gasoline keep the R P Ms around 1500-1800 so the treatment gets into the slow circuits. When you get done with that park it for at least a day so the stuff can work. Do that a couple of times and hopefully it will clean it up. As some others have found out IF the chemicals don't clean it up you MIGHT be on the way to a carburetor tear down and cleanup. Try the chemicals first. Keep us updated on how it's going for you. RIDE SAFE.
valkyt6
« Reply #5 on: February 20, 2013, 05:34:16 PM »
hi
could be the foam insert in the inlet to the air filter box, mine perished so remove all of the foam had a big flat spot on excel until I made up a replacement.
regards greg
localyokel
Newport Beach CA
« Reply #6 on: March 04, 2013, 11:13:48 PM »
First, congrats on scoring a low mileage Valkyrie.
I imagine you actually have 6 into 2 Cobra pipes as 6 into 1 would be a plumbers nightmare...
Need a little more info.  Does the bike exhibit just a flat spot or does it stumble and pop when you quickly open the throttle, then wind up normally?  Or is it something else you're experiencing?
Please give a little more info.  Do you have stock air filter or K&N?  Have you done any mods such as trigger wheel, ECT mod, or inline fuel filter?
Good luck...maybe we can steer you to the solution.
Blew it on my post, 6-6 cobras not 6-1! Everything else is bone stock.  Stumbles mostly off idle at low rpm. Cruising/roll-on is fine. Not familiar with sea foam as others mentioned.
« Last Edit: March 04, 2013, 11:16:28 PM by localyokel » Logged
