August 03, 2025, 04:24:39 AM *
Author Topic: 4 degree mod. on trigger wheel- where?  (Read 1231 times)
BigM
« on: February 20, 2013, 07:46:26 AM »
Ae 100k on the beast. I have the I/S and have been running the 6 deg. TW. Going to change the belts and make the std. TW to a 4 deg. Any idea on where to find info. on filing the std. to make 4 deg. ?
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #1 on: February 20, 2013, 08:10:07 AM »
JUST ORDER A NEW 4-DEGREE WHEEL .... MUCH LESS TROUBLE.
« Reply #2 on: February 20, 2013, 08:41:10 AM »
Why not just put the 2 wheels together and align the teeth. Then file 1/2 the difference of the key. Should be about 1/32"
BigM
« Reply #3 on: February 20, 2013, 08:51:43 AM »
One thing havent seen where can order 4 deg wheel. Only 6.
 Good idea on putting the two together. and take half the dif. By running the 6 in my I/S seems maybe to have more whine noise. Plus good take off but drags down on inclines. Would that be the case with the 6 in the I/S?
tank_post142
south florida
« Reply #4 on: February 20, 2013, 09:59:00 AM »
http://wingstuff.com/products/20358-timing-advance-trigger-wheel?sitesync=done
http://cyclemax.com/inc/sdetail/gl1500_valkyrie_trigger_wheel/167424/159787
http://www.straightwings.com/store/97-98-6-degree-trigger-wheel-VALKYRIE.html
http://cyclegiant.com/shop/gold_wing-trigger_wheels?dir_=XxX1329008674919XxX
« Last Edit: February 20, 2013, 10:02:57 AM by tank_post142 » Logged
I got a rock Sad
VRCCDS0246
BigM
« Reply #5 on: February 20, 2013, 10:17:23 AM »
ok thanks for the links. I have the stock so filing should be same right?
Also would the degree wheels take away from top end? As I stated before. Seems like the 6 I have in now. I have less pull on hills. More throttle needed and not much power on hill sides.Would that be the case?
« Reply #6 on: February 20, 2013, 10:23:57 AM »
These engines do not like a lot of advance, about 27º tops. I prefer the tooth profile of the original wheel rather than the aftermarket.
BigM
« Reply #7 on: February 20, 2013, 11:12:59 AM »
So you think would be best to just go back with the orig.? 4 wouldnt make that much dif.? Would i be able to tell much dif. going from 6 to stock? I have ran the 6 for prob. 50K. But said seems to lag on hills and may be getting noisier or my imagination. One reason my son was here when I started it up. He said that seems like alot of noise from engine. Got me wondering with 100K now.
« Reply #8 on: February 20, 2013, 12:00:42 PM »
Personally I feel that 6º is too much, but, some [ like you] have used them for years without any apparent ill effects. The main thing I have noticed is hard cold weather starting and some have a high pitched vibration.
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #9 on: February 20, 2013, 02:08:46 PM »
Just leave it stock with the IS module installed .... I have run it all 3- ways, and the To-Jo Honda wheels are better.  If you are bound to change it, then buy a 4-degree wheel new instead of filing the stock one down.
Tx Bohemian
Victoria, Tx
« Reply #10 on: February 22, 2013, 07:45:23 PM »
...buy a 4-degree wheel new instead of filing the stock one down.
What's the problem with filing the stock one?
Al
Brian
Monroe, NC
« Reply #11 on: February 23, 2013, 05:20:58 AM »
100k you may need new timing belts and check the bearings in the tensioners. I had one go out with only 14k on it. The tensioners can be easily rebuilt using a car idler pulley for around $25 verses $80 each. I did one where I posted pictures on this site as well as do the google. It will pull up the goldwing article that I used.
