February 06, 2026, 11:26:13 AM *
Author Topic: Swing arm bearings  (Read 1388 times)
sabrehonda
« on: February 22, 2013, 11:44:37 AM »
Does anyone know the "grease retainer plate" part # that backs up the swingarm bearings?  Not showing up on any parts diagrams or lists, yet it needs to be destroyed when changing the bearings.
Misfit
Colorado Springs Colorado
« Reply #1 on: February 22, 2013, 12:06:44 PM »
Those pieces will come with your new bearings.
jimmytee
Elizabethtown,KY
« Reply #2 on: February 22, 2013, 08:41:09 PM »
Sabrehonda
How did you determine your bearings needed replaced? Did you feel play from side to side our ride issues?
bentwrench
Philadelphia,Pa.
« Reply #3 on: February 23, 2013, 08:17:59 AM »
I don't think you can wear them out.At around 50k I took mine out repacked with belray waterproof grease.
I made index marks on the adjuster bolt before I took them apart,and when i was done setting them to spec the index lined right up with oe setting.
Havn't given them another thought since
BW
Earl in Pensacola
« Reply #4 on: February 24, 2013, 04:01:12 PM »
At 263K mine have never been nor needed replacement and still don't!!  However, I have replaced the  rear wheel bearings a couple of times.
xman
Lincoln Park NJ, Valk Home Lackawaxen PA
« Reply #5 on: February 25, 2013, 03:23:58 PM »
Always wondered if the swing arm bearings could be greased, but never found a zert fitting. BW, is there a maintenance procedure for what you did?
Tom
« Reply #6 on: February 25, 2013, 05:32:58 PM »
Tom
It is covered in the manual. I did it with the Honda tools, it was very easy that way, and
also made it so you could torque it back following the manual's instructions...
