February 06, 2026, 11:34:28 AM *
Author Topic: carb o-ring lubricant suggestions?  (Read 5653 times)
Brian
Monroe, NC
« on: February 28, 2013, 03:10:34 AM »
Hey,
Reading the thread "I smell gas" has me and my girl in the same situation. I had been smelling a slight gas odor on off for a while thinking it just coming from the gas cap. I tackled the driveline maintenance this past weekend and discoverd gas dripping off the bottom of #6 carb. The exterior of the bowl is damp not really pin pointing the leak. When I cleaned the carbs in 06 the only o-rings replaced then where on the fuel rails. I am going to remove the carbs here soon to find and fix this leak.
I took the suggestion of buying the complete gasket kit from Redeye, even the gaskets for the bowls. Rich recommends using Seafoam as the o-ring lube or treatment. Is this really the best product or can something else be used in it's place. I view Seafoam as more of solvent or cleaner.
9Ball
« Reply #1 on: February 28, 2013, 03:52:58 AM »
Are you sure it's not your petcock leaking?  Or a split in the vacuum line from #6 to the petcock?
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
« Reply #2 on: February 28, 2013, 04:45:16 AM »
silicone grease aka di-electric grease for the o-rings.
using seafoam would be a dumb thing to do.
fordmano
San Jose, CA.
« Reply #3 on: February 28, 2013, 03:26:11 PM »
Di-Electric grease (AKA: Silicone Grease) for the win!!!  Cheesy cooldude
It's as clear as the writing on the Can.  Roll Eyes
« Last Edit: February 28, 2013, 03:30:58 PM by fordmano » Logged
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
YoungPUP
Valparaiso, In
« Reply #4 on: February 28, 2013, 04:44:44 PM »
Just curious, by why would using Sea foam not be the lubricant of choice? It is whats recommended by the person selling (making?) the product. It says on the can that it has lubricant in it.
99 STD (Under construction)
Brian
Monroe, NC
« Reply #5 on: March 01, 2013, 03:09:02 AM »
The petcock leak and vacuum line taken care of when I installed a new manual Pingle. Thanks.
Brian
Monroe, NC
« Reply #6 on: March 01, 2013, 03:16:11 AM »
The die-electric grease or silicone was going to be my choice and glad to see others here recommend it.
Thanks guys,
