February 06, 2026, 03:02:14 PM *
Author Topic: Dyna 3000  (Read 1282 times)
Mallett
Oh, what a ride!!!!
Laurel, Mississippi
« on: March 05, 2013, 05:49:37 AM »
This is a question for you guys that have the Dyna 3000 installed on your Valk. I put a new set of tires on my gurl recently & decided this would be a good time to see just how fast she would go. On my first try I had the Dyna set on 3 (the setting it was on when I bought it) & I hit a max speed of 131 mph on the speedo. And then changed the setting to 7 & was only able to reach 126 mph. Can someone explain to me why it runs faster top in on 3?
Any coward can fight a battle when he's sure of winning; but give me the man who has pluck to fight when he's sure of losing.
GEORGE ELIOT
BonS
Blue Springs, MO
« Reply #1 on: March 05, 2013, 06:25:18 AM »
I'm no guru but looking at the advance curves and your top speed reductions suggests that curve 7 may be simply too much advance for your setup. Dyna says curves 6 and 7 are for engines with modified exhaust and jets. Are you running premium to avoid detonation?
Mallett
Oh, what a ride!!!!
Laurel, Mississippi
« Reply #2 on: March 05, 2013, 09:31:04 AM »
BonS, I was running premium gas the day I ran the test but it runs just as well on 87 octane. What I think is happening is it is starving for gas...I have the rev limiter set at 8000 so I know I'm not turning that many rpm's at 131 mph....
GEORGE ELIOT
« Reply #3 on: March 05, 2013, 10:32:39 AM »
I don't know about the Dyna settings, but, these monsters do not like much ignition advance. 27ยบ is about tops, power falls off pretty quick beyond that.
« Reply #4 on: March 05, 2013, 01:54:45 PM »
http://timskelton.com/valkyrie/tech/trigger_wheel_plus_dyna3000.htm
