I just bought an 03 standard that has 10,000 miles on it. It has been ridden very little during the past 2 years (second owner rarely rode it). At idle and at low speeds it has a very pronounced miss. Once you rev it up and get to highway speeds it smooths out. I am currently running some Sea Foam in gas and hope it is just dirty carbs. Any other suggestions on what I may be looking for?
If you are not putting a FULL can of Seafoam in the tank do so before ya tear the carbs out............. The little dab will do ya that they recommend will NOT do it......
I used a partial can about 10 years ago in Florida and cussed the stuff till we got home. Then I put a full can in and rode it, it cleared up. So, every since then I use a FULL can per tank full if I have a carb problem, and every winter it gets a full can to keep things clean during the winter months......
