February 06, 2026, 03:02:11 PM *
Author Topic: Wheel rims for a 2000 Std?  (Read 1175 times)
BamaDrifter64
Athens, Alabama
« on: March 13, 2013, 09:46:09 PM »
What year and model rims will fit a 2000 Std w/o any mods?
olddog1946
Moses Lake, Wa
« Reply #1 on: March 13, 2013, 11:08:46 PM »
I believe any of the wheels from other years will fit. I do know the 97 front has a different set of bearings. And the offset on the rotors from other years may be different so you may need the brake setup for the year wheel you are going to use.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
« Reply #2 on: March 14, 2013, 12:10:10 PM »
I can never remember from one day to the next all the details... I know that on Wimp's 97 the rotor
had to be shimmed for him to use his newer rim. It might be that if you have a newer bike, you can't
use an older wheel, since you can't "unshim" the rotor... when he and I were studying it,
we found what we thought was authoritative information by searching on the tech-board... it might
also be that if your wheel and rotor are from matching years, you're good-to-go no matter what
year bike you put the wheel on.
-Mike "the tech-board remembers..."
« Reply #3 on: March 14, 2013, 09:49:48 PM »
Going from memory, the rear rims are all the same, and it was the front rim that had a different size bearing.
Rotors need to stay with the bike, or may require shimming to make it fit to the brakes.
Newer rims might have clear coating, 2000+.
