February 06, 2026, 04:36:29 PM *
Author Topic: IS CB radio mount  (Read 1547 times)
PhredValk
Edmonton, Alberta, Canada
« on: March 17, 2013, 11:42:02 PM »
Does anyone have a good photo of the under-trunk CB radio mount? I can't find one and would like to fabricate same.
Fred.
VRCCDS0237
9Ball
« Reply #1 on: March 18, 2013, 04:59:13 AM »
Did you look at the reply to your previous post....not a photo, but the CB installation manual shows the brackets.  You should be able to fab what you need from the diagram....they are only metal straps that make the bracket...and the needed 6mm flange bolts and spacers are pretty clearly shown.
http://www.valkyrieforum.com/bbs/index.php/topic,52492.0.html
Good luck with your project...
« Last Edit: March 18, 2013, 05:01:16 AM by 9Ball » Logged
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
« Reply #2 on: March 18, 2013, 05:42:04 PM »
That plus looking for on advertised on ebay, is how I figured to modify and then mount the radio under my trunk.
PhredValk
« Reply #3 on: March 19, 2013, 01:05:02 AM »
Thanx, 9ball, I forgot about that post. I've been checking E-bay and Pinwall for months. I should be able to cobble something together from those pics. Thanks to Dag as well. I can't put it under the saddle because I need room for a larger than stock battery to go with the 90 AMP alternator, and the stock radio and power amp for the Polk speakers.
Fred.
« Last Edit: March 19, 2013, 01:10:50 AM by PhredValk » Logged
VRCCDS0237
9Ball
« Reply #4 on: March 19, 2013, 04:12:43 AM »
you're welcome...
...and maybe someone will snap a picture showing the completed installation so you can see what it will look like.   cooldude
hope this helps.
« Last Edit: March 19, 2013, 04:16:19 AM by 9Ball » Logged
1999 Standard
2007 Rocket 3
2005 VTX 1300S
Novavalker
99 Interstate/2017 Goldwing
« Reply #5 on: March 19, 2013, 04:24:37 AM »
You could modify a 1200 GW bracket.
http://www.ebay.com/itm/NEW-HONDA-GL-1200-GOLDWING-O-E-M-R-H-ANTENNA-MOUNT-/150475719120?pt=Motorcycles_Parts_Accessories&vxp=mtr&hash=item23090d41d0
9Ball
« Reply #6 on: March 19, 2013, 04:41:43 AM »
that's an antenna mount...he needs the CB box mount
I found a few pictures of the mounting brackets installed on the radio for your info...
http://www.ebay.com/itm/01-Honda-Valkyrie-GL1500-1500-CB-RADIO-VIDEOS-/130802623653?pt=Motorcycles_Parts_Accessories&hash=item1e7471a4a5&vxp=mtr
This link has some nice pictures so you can see what it looks like from both sides.
http://www.ebay.com/itm/97-03-Valkyrie-Interstate-GL1500CF-Clarion-Hondaline-CB-Transciever-Radio-/190813313949?pt=Motorcycles_Parts_Accessories&hash=item2c6d5c1b9d&vxp=mtr
You should be able to fab this up in less than an hour on your workbench using a vice, hacksaw, and drill bits.  I'd use 1/8" thick by 3/4" wide flat stock aluminum instead of steel.  Easy to cut, bend and drill.  Most hardware stores have what you need.
« Last Edit: March 19, 2013, 04:58:41 AM by 9Ball » Logged
1999 Standard
2007 Rocket 3
2005 VTX 1300S
PhredValk
« Reply #7 on: March 19, 2013, 04:52:01 PM »
Thanx, Nova, I have the antenna mount already.
Thanx again, 9Ball, those pix are much better, and will do nicely.
Fred.
VRCCDS0237
« Reply #8 on: March 19, 2013, 08:21:31 PM »
Phred, have you considered a Lithium battery instead? Look for one with the correct oritation of the battery terminal, and has the same CCA or better than the Valk battery.
http://www.shoraipower.com/
You can look up the different physical sizes and CCA of the battery.
I saw this at the winter motorcycle show, I thought it was an empty plastic case for show, but the salesman assurred me that it was the actual battery.
F6BANGER
Albuquerque NM
« Reply #9 on: March 20, 2013, 09:14:33 AM »
Who wants to help me clean this dirty bike.......LOL
I just recently gave one of those away. Dont remember who I gave it to.
« Last Edit: March 20, 2013, 09:20:00 AM by F6BANGER » Logged
Highbinder
Bastian/Tazewell,VA.
« Reply #10 on: March 20, 2013, 02:51:13 PM »
I have one of those mounts hanging on my shop wall, shoot me a PM... cooldude
9Ball
« Reply #11 on: March 20, 2013, 07:52:19 PM »
is this the best club, or what?
1999 Standard
2007 Rocket 3
2005 VTX 1300S
« Reply #12 on: March 25, 2013, 05:21:35 PM »
here is one on ebay with all the pics of it off the bike.
http://www.ebay.com/itm/97-03-Valkyrie-Interstate-GL1500CF-Clarion-Hondaline-CB-Transciever-Radio-/190816323287?pt=Motorcycles_Parts_Accessories&hash=item2c6d8a06d7&vxp=mtr
(and for others, only $350, so I'm sure this wont last long).
PhredValk
« Reply #13 on: March 25, 2013, 08:09:19 PM »
Highbinder, PM sent. I already have the radio and antenna with mount.
Thanx, guys,
Fred.
VRCCDS0237
