November 25, 2025, 07:28:56 PM
fork oil leaking
Topic: fork oil leaking (Read 880 times)
hrapp
Rosharon,tx
fork oil leaking
March 19, 2013, 04:13:49 PM »
the front forks have oil and collective road dirt. thought it was the brake master. that's still good. the stealer dealer did change the oil about 6 months ago. now looks like its leaking. maybe they over filled?
1997 valkyrie tourer
1972 shovel
2009 vtx 1300r
1995 sportster
jimmytee
Elizabethtown,KY
Re: fork oil leaking
March 19, 2013, 04:40:14 PM »
try these they are called Sealmate
http://sealmate.net/
There are also those that have used what they call the 35mm film trick utilizing what else, 35mm film. Search it.
hrapp
Rosharon,tx
March 23, 2013, 03:09:09 AM »
Interesting. I could make that tool out of a teflon sheet. aka: cutting board. Just need to find out about the dust cover removal, if it can be done. item 27 on fork assembly
1972 shovel
2009 vtx 1300r
1995 sportster
March 23, 2013, 06:51:32 AM »
The dust cover is removed by prying it up with a very small screwdriver. It's just pressed in and isn't very tight.
=> InZane XXV
