February 06, 2026, 04:36:14 PM *
Author Topic: Pingel installation question  (Read 1651 times)
Thulsa Doom
Rhode Island
« on: March 23, 2013, 02:48:02 PM »
 uglystupid2
I'm ready to install my new (non-vacuum) Pingel. I removed the gas tank and the stock petcock has a fuel line and two, smaller hoses connected to it. The Pingel only has a connection to the fuel line. What do the other (small) hoses do and what am I supposed to do with them?
... and as I shifted into second I couldn't remember a thing she said.
« Reply #1 on: March 23, 2013, 02:56:02 PM »
Those were the hoses that feed vacuum to the OEM petcock, the other was a vent hose.
On mine I removed them from the other end and then either capped or plugged where they came off of.
If you don't put on the Dan Marc solenoid, make DAMN sure ya turn the gas off whenever you turn the motor off.     If you don't you stand a very good chance of filling a few cylinders with GAS.    NOT good on starter gears.
It is commonly called Hydro Lock.
« Last Edit: March 23, 2013, 02:57:59 PM by R J » Logged
« Reply #2 on: March 23, 2013, 03:21:19 PM »
uglystupid2
The OEM petcock should only have a fuel line (big hose) and a vacuum (small hose) thats it.  If you have 3 hooked to the petcock thats not normal.
All you should have to do is connect the fuel line with a clamp because the pingel fuel nipple is smaller and then cap off intake nipple #6.  Done.
tank_post142
south florida
« Reply #3 on: March 23, 2013, 03:25:38 PM »
that 3rd line should attach to a vent pipe near the rear of the tank. yes it will have a T fitting a little way down that has one side not connected to anything. it is a vent hose with a vacuum break.
I got a rock Sad
VRCCDS0246
Bigun
VRCC# 32964
Monroe, Iowa
« Reply #4 on: March 23, 2013, 04:14:39 PM »
Do you have a link for the solinoid RJ? I'm in the process of replacing a motor due to Hydro Lock and would rather not repeat the process. Already have the Pingel petcock.
1999 Valkyrie Interstate
Thulsa Doom
Rhode Island
« Reply #5 on: March 23, 2013, 05:45:32 PM »
Done!
One fuel hose.
One vacuum hose to #6.
One vacuum hose from rear of tank.
Yeah I had lost track of the hose on the back of the tank.
Took the bike out to fill the gas tank and it seems to work ok. No leaks.
« Reply #6 on: March 23, 2013, 05:46:07 PM »
Bigun, did you send me a PM on this?
If so ya should have the info.
If not, send me a PM and I'll get ya the info.
Thulsa Doom
Rhode Island
« Reply #7 on: March 23, 2013, 05:59:11 PM »
Would you mind posting it? It seems like a good idea that I might consider.
tank_post142
south florida
« Reply #8 on: March 23, 2013, 06:29:57 PM »
http://www.horseapple.com/Valkyrie/Tech_Tips/Fuel_Shutoff/fuel_shutoff.html
http://www.dan-marc.com/79-afc11112.html
« Last Edit: March 23, 2013, 06:31:38 PM by tank_post142 » Logged
I got a rock Sad
VRCCDS0246
